Best downpipe for GMPP exhaust setup
Old Dec 13, 2008 | 03:59 PM
BaltZ SS's Avatar
I'm thinking about going with the GMPP extrude honed manifold (I know, I know, not the best choice but I found one for dirt cheap and I'm going to try to get it ported) and the GMPP touring exhaust for my LSJ. Since there is no GMPP downpipe and the stock one is pretty restrictive I would like to know what my best option is for an aftermarket down pipe that will fit these parts. Oh, and I would like to get one with a cat. Any suggestions?
Old Dec 13, 2008 | 04:02 PM
bshoe421's Avatar
CA's XTC downpipe, will bolt right up to that set up
Old Dec 13, 2008 | 04:16 PM
greekss's Avatar
i've got my stock ss/sc dp if you want, complete with cat....idk if it is compatible or not, but it should work? someone around here will know...offer stands if you want, price negogiable
also have the stock headers
and exhaust but its been cut in half so i could remove it...
ha just realized the thread this is under
nvm about the previous
i'll be honest, i went vibrant header/dp combo, with the magnaflow - its a great setup, good sound, and looks nice too. as far as performance goes, depending on what you run on the blower and other engine mods, 2.5 piping should be just the right size. I noticed a slight drop off in psi's (like half a lbs) was only hitting about 14psi's but the 2.9" fixed that up real quick
back to exhaust components thou...imo, if you are going to spend the money, spend it on something worth it. get a good setup, stay away from gmpp imo. wont give you the satisfaction you want and its almost as expensive if not more than other better parts...do some searching around here, there are plenty of threads on this topic btw so you can get a better idea
Old Dec 13, 2008 | 04:22 PM
BaltZ SS's Avatar
I have the stock downpipe but I'm looking for a less restrictive aftermarket one. Thanks for the offer though.
Old Dec 13, 2008 | 04:34 PM
YellowBalt06's Avatar
yeah is there any aftermarket header/downpipe that does not cause a check engine light??
Old Dec 13, 2008 | 04:44 PM
greekss's Avatar
no problems with my vibrant dp, but it only comes as combo header/dp....I havent had a cel since i got my stg. 2 about a year and a half ago ::knocks on wood:: and i've got full bolt ons, intake header dp exhaust....
anything you go with should be fine as far cel's go...just make sure you don't go for a highflow cat or something like that. from what i understand that could make the o2 sensor go goofy...might cause some problems that and you don't need a highflow cat or to be catless for that matter...our blowers like a little resistance, not enough back pressure means less power, unless you are running something smaller than a 2.8 with a tune and supporting mods, in which case your engine MIGHT be pushing enough air through to benefit from the highflow cat
Old Dec 14, 2008 | 09:33 PM
ic so as long as i get a header/downpipe without a highflow cat i shouldnt get a check engine light and dont need to tune anything? or is most downpipes regardless gonna cause a check engine light?
Old Dec 15, 2008 | 01:17 AM
jonnymerk's Avatar
I have the zzp downpip with high flow cat. The check engine light is on but the combo sounds great with my touring exhaust. My thought is if you get a downpipe might as well get the high flow cat, why not have the best flow possible. I think you can get a cel delete anyway from arc or some vendor
Old Dec 16, 2008 | 12:18 AM
BaltZ SS's Avatar
I would imagine a catless downpipe would be more likely to throw a code then one with a high-flow cat.
Old Dec 16, 2008 | 12:21 AM
ShortStack's Avatar
A catless dp will flow better
stock cat for ss/sc is high flow, its just the pinch that needs to be worked. Go to muffler shop and have them weld a pipe in place there
if not, the cobalt addiction one will bolt up
Old Dec 16, 2008 | 04:25 PM
greekss's Avatar
honestly guys, unless you are running something smaller than a 2.8" pulley, with the supporting mods - you dont really need a high flow cat, or to even go cat-less - you could stand to lose more power than you would gain. the superchargers need back pressure to be effective....
Old Dec 16, 2008 | 04:29 PM
ShortStack's Avatar
no.. wrong
superchargers do not need back pressure to be effective...
dont listen to that last post, it will screw you up.
reminder, the stock ss/sc cat IS HIGH FLOW.
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
