best mods for a grand
ottp stage1 and rotated mounts(if you want to drag)
ottp stage1 and tuned meth injection(agressive DD setup)
ottp stage1 and intake and h/e(pretty nice DD setup)
or if you don't want power:
ottp rotated mounts, TTR upper mount, front/rear sway bars, strut bar
crap... well IMO. get a 2.5 exhaust with midlength header/dp setup. ott1 is g2g! i would not get it unless i had the supporting mods as stated above. get the exhaust first and intake then get the kit.
ott stage 1 kit is great on everybody that i have talked to and has it. i have one on the way right now this week
should b nice. get the stage 1 kit from them and a heat exchanger. then if u dont have intake or full exhaust upgrade that. if u dont want to stage then get full exhaust and intake first if u want.
The GMPP touring sounds great , but if i had to do it again i would buy a Corsa touring for the 2.5'' size. Do you have /or are you worried about the GM warranty? If so that changes some of the parts you should buy.
the gm warranty is up in 10k i am not worried after that to much i am getting a new head put on it i'll get it back tomorrow. other than that it is the only real issue have been having. what is the ott stg1 bring the horsepower up to and how is it with a stock exhaust or just a cat back
ott stage 1= better than gms. bigger injectors and smaller pulley up to240-260 hp on the car depending on ur other mods so the more mods the better hp you will gain then getting a better tune than what they ecu they kit bring has will help more. also cooling mods you will need maybe an extra heat exchanger or a dual pass. or meth
i'm going to suggest the OTTP stage 1 kit with 2.8" pulley, injen cai, & the OTTP h/e kit. for $1k, that's some really good mods and you notice a huge difference. and then when you have another $1k to spend on parts, i'd recommend getting the CTI header/downpipe combo & cat-back from OTTP. and then save up some more money and get the the rotated tranny mounts from OTTP, these will completely eliminate wheel hop so you wont have to worry about your axles.
The mount's are going to be my next purchase, i'm sick of worrying about the tranny case, and babying this thing out of 1st .
