which is the best traction modd ?
Go with the tranny mounts. There cheap and work well. I got mine from www.cobaltperformanceparts.com when I had the balt. One of the best mods I did.
Go with the tranny mounts. There cheap and work well. I got mine form www.cobaltperformanceparts.com when I had the balt. One of the best mods I did.
i dont know how well they stopped my wheel hop but by far one of my favorite mods, greatly improves your shift response
It has been shown also that the motor mount is over rated unless you are pushing some high Hp. The cost of the tranny mounts are cheap and they eliminate the wheel hop better then the motor mount.
There are 3 mounts total that you can stiffen up.
2 transmission and 1 engine.
2 Tranny bushings are really cheaper ~$50.00 the engine Mount is ~$200.00
If you get a complete set through us, when you purchase the engine mount, you can get the tranny bushings for only $29.99
not an easy install, not just a little more vibrations, took me an hour and i was a mechanic untill two weeks ago. My new nickname for the car is the vibrator. (My fiance calls it foreplay)
talking about tranny mounts, sry...
anyway i have had experience with all and from my experience control arm bushings are he most effective wheel hop reducer pair them with tranny bushings and you are pretty good.
what injectors are you using?
unless the injectors your using now are having trouble doing the job....new injectors are going to give you 0 power.
if your on the stock tune, im sure a good tune can net you a few ponies though.
but nothing will bump up your power like a lb or 2 of extra boost.
I've got the Bwoody engine and tranny mounts... personally the tranny mount is doing the most for me. The engine mount just looks good under the hood... so it's saying.
I'd stay away from the traction bars... they hang down under the car so they can scrape... plus you need to re-grease them often so they don't creak and make your car sound like junk.
I will let you know how my set up goes. Will be done with all my installs by the end of the month.
Stock From Factory: 14.2 @ 100mph
Old Mods: GMP Stage II, GMP Touring Exhaust, Ingall's ETD, Injen CAI = 13.6 @ 107mph
New Mods: B&M Short Throw, GMP manifold, ZZP DP with high flow cat, TTR Engine Mount, TTR Front/Back Tranny Mounts, BFG DRs, Exedy Clutch/flywheel, CA H/E, GMP Dual Pass, Nate's 2.9 pulley = ? unknown
2.12 60' 13.89@103.2 mph thats on 100 octane (car ran like **** for a few days later afterwards tho) is my best time car was also gutted just one seat and no speakers or spare
14.19 @ 101.3 mph without the 100 octane and no track prep
you also have to keep in mind im running at sea level, the humidity is high but when its cold the car is amazing
springs and good tires are ur best traction mods
also it is a piece of cake to change them...just take ur sweet time..i changed mine in under 30min,and that was while i was playin around with my lil bro..need any help just pm me a message and ill answer ur question
