Big hole, lower grill....
Old Jul 26, 2005 | 02:06 PM
love my SS's Avatar
Originally Posted by stealththx
The specific name for this mesh is called Gutter Guard. I just put it on last night and damn does it look nice...at least on the yellow. Anyways, I picked up a sheet for $1.57 that covered the entire opening at Home Depot. Yes, thats right is was less than $2! Depending on where you live you might want to try Lowe's or Menards as well. Just go into the gutter department and look for gutter guard though and you will be suprised how cheap this stuff is.
lol...i was thinking of gutter gaurds myself! thats really wild. so it works well, great. Does the cable ties hold pretty good force against it, ie keeps rocks and debris at bay? I figure a rabbit or other small animal is gona do damage anyway, just want to keep as much damage from that area as possible. thanks for the r & d with gutter gaurd mesh!
Old Jul 26, 2005 | 04:02 PM
stealththx's Avatar
The cable ties hold really well and they are invisible unless you try to find them on there. The holes are a little big so smaller rocks can still get in there but it will protect against anything that would be big enough to cause any damage i.e. small animals. Of course the only way to fully protect the intercooler from everything would be to fully block it off, defeating it's purpose. The gutter guard looks really nice though and I swear it is the same stuff they have at Advance Auto for $35.
Old Jul 26, 2005 | 06:17 PM
alleycat58's Avatar
Originally Posted by 2006ArrivalBlueSS
I think she already explained all that. Please take the time to read and save yourself, as well as others, a lot of time. One thing you'll get to know about Alicia is that she is very thorough, very helpful and she TAKES THE TIME to read posts to reduce redundant questions like yours. Thank you.
Hehe, thanks!
As far as other people who mentioned gutter guard, the reason I went with the automotive stuff is because I've known a couple of friends who used the gutter guard and it didn't seem to hold up as well long-term. It looks the same, hell even feels the same, but a friend of mine had it on his ITR and said he didn't think it held up as well...it seemed to get bent more easily. Mine has gotten hit with a couple of stones and some bugs, and has yet to so much as dent.
In the long run, the gutter guard may be cheaper still even if you replace it a couple of times. I just went with the auto store stuff because that's what my friend recommended after he replaced the gutter guard with it. Like most stuff, it's personal preference.
As for the cable ties, they hold up great...you have to cut them in order to get them off...they can stand a surprising amount of pull on them.
Old Jul 26, 2005 | 06:19 PM
player_1's Avatar
Originally Posted by Chevy4Life85
doesnt someone on here have the 06'? is there a grille??
also I'm always the one giving this point of view..
if you have a 1 sq ft opening, and you put a screen over it, it will get less air than without the screen.
Same goes with your car, put a grille on and you will get less air, should be fine but its common sense that you wouldnt get as much
less air is an incorrect statment, what you reall mean is lower air flow.
and as I explained to people on other posts that, the air flow is not an issue in this area of the car.
you will still have more then enough fresh air to keep the engine cool, especially when driveing.
worrying about the reduced air flow in this area of the car is a none issue, unless you were to run a Short ram air (or scoop) to this area.
Old Aug 2, 2005 | 09:11 PM
RA071623's Avatar
I was washing my car and trying to remove bugs from the intercooler and noticed that some of hte fins have moved slightly so that you can notice the different color. So perhaps a guard is not all that absurd. Anything larger then a fat bug would probably make your intercooler less attractive lol.
Jason
Old Aug 2, 2005 | 11:26 PM
alleycat58's Avatar
Jason
Mine seems to be getting the job done, not a single bug has made it through since I installed it....but many have died trying.
Old Aug 3, 2005 | 02:08 AM
mtwal16's Avatar
use gutter guards
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
Dylan Johnson
Sep 30, 2015 08:57 AM
Slick_Nick
Sep 28, 2015 09:15 PM
