Big problem with LSJ.
Old Nov 20, 2005 | 03:01 PM
BullDog71ss's Avatar
http://videos.streetfire.net/Player....rm=redline&p=2
Watch this vid. Mine does this exact same thing at about the same time his does. It started sometime after the CAI, I dunno if the CAI had anything to do with it though. Does anyone else experience this?
Old Nov 20, 2005 | 03:12 PM
JonyyB's Avatar
Site Founder
dude you hit the redline in 3rd! shift dude shift!
nothing's wrong with your car
Old Nov 20, 2005 | 03:14 PM
cvenom2122's Avatar
Thumbs up
running lean.. go get all you PCM updates and see if that helps if not wait till Stage 1 youll be fin (hopefully) I had the CEL come on 1 time so far and that was the dau i got the intake next day gone!
and he redlined the damn thing past 65000 rpms a
Old Nov 20, 2005 | 03:27 PM
MarcS's Avatar
The Stig
lol, yes. You must shift.
Old Nov 20, 2005 | 03:39 PM
Cobalt_Supercharged's Avatar
Yeah, I hit the red line in first a few times. That's what happens to me, but I think Bulldog knows better than that. When does it happen?
Old Nov 20, 2005 | 03:44 PM
Wait I just watched that again in full screen mode. Watch the tach closely in the middle of 3rd. It reaches about 5k then jumps to 4k and then back while the engine is still accelerating, just before he shuts it down.
I don't know if mine does it or not, too busy watching the road.
Old Nov 20, 2005 | 03:47 PM
R33P3R007's Avatar
360 L337 User
yeah i see it too. but never happen to me
Old Nov 20, 2005 | 04:38 PM
SloBaltSS's Avatar
Its happened to me before.... mine didn't misfire or anything, its just the tach spazzing a little bit. I've noticed it 2 or 3 times....
On a related note... if you tach out the new solstice with the clutch in the speedo will pump to like 10mph for a split 2nd.... the one I test drove did it every time...
Old Nov 20, 2005 | 04:54 PM
sounds like an ecu glitch.
Old Nov 20, 2005 | 04:56 PM
SilverSS/SC's Avatar
You can definately see the RPM drop . Its more than the tach spazzing out , cuz the sound of the engine correlates with the rpm drop . It doesnt really sound like a missfire to me at all . Sounds more like the ignition or fuel is getting completely getting shut down for a split second . My car has never once done this .
The car isnt shutting down at the end of the vid . He put it neutral
BullDog71ss - run a scan tool ( if u have access ) on your car and see what exactly the spark advance and 02 values do .
Old Nov 20, 2005 | 05:33 PM
97cavie24ls's Avatar
my friend that just got a 04 red line hasnt been able to pull past 100 mph
and at some point the CEL started flashing in 4th , andhe wasnt close to redline yet
its going in mondya to see if they can find anything
Old Nov 20, 2005 | 07:08 PM
GeoChevyCobalt's Avatar
I think I have only seen this once or 2 befor. I really do not drive the car that hard any more so I really do not know. I know that the car has hiccups sometimes but I can only think that it could be do to the closed fuel rail. No return line. Might be that some times the Fuel rail gets drained enough for a hiccup. I am just guessing on this one though. Also it makes sens that the 3 ticka ticka sounds that I hear when I shut off the car is that it is relieving excessive pressure in the line so it dose not wear seals. This is also a just my opinion. To verify this some one need to monitor the pressure in the fuel rail to see if it dips down and if the car's rpm follows this dip. I think you would only experience this under WOT for an extended period of time. Dose anyone know were someone can monitor the fuel pressure that the CPU sees?
On a side note my 05 ss sc is running grate. It has power when I need it but I mostly drive at speed limit.
Old Nov 20, 2005 | 10:59 PM
3fo893013L's Avatar
My Cobalt does that, I actually had taken it to the dealership after I put 3k miles on it to be sure and that problem is related to to much air, not enough fuel they said. It hicups. A programmable reflash was done but turned out the intake was choking the supercharger in high boost conditions.. lovely isn't it? the problem stopped after the K&N was installed.
Old Nov 20, 2005 | 11:15 PM
Bulldog has the K&N CAI though, and noticed it after he installed it. See first post.
Old Nov 20, 2005 | 11:27 PM
3fo893013L's Avatar
Well don't know what to tell him, sounds like his throttle body is sticking closed when shifting between gears for a quick sec if he is not power shifting.
Old Nov 20, 2005 | 11:33 PM
Yeah, I wish I knew what it was incase it happens to me. Guess we will have to wait and find out. He replaced one engine already, what's another?
Old Nov 21, 2005 | 10:59 AM
2K2CamaroSS's Avatar
Mine missfires occasionally. It does it every now and then only under WOT and only between 3K-5K RPM's, did it before and after I installed my K&N intake. No one believes me and the delear cannot duplicate the issue so, therefore they wont do anything about it.
Old Nov 21, 2005 | 12:01 PM
It's definetely NOT me hitting the rev limiter. I'm not that effing stupid. It's a hiccup in the fuel/spark at around 5,000-5,500 rpm on full throttle runs in 3rd and 4th gears. It's also has nothing to do with gear changes as it happens long after the gear has be selected. It really does feel like the car just runs out of fuel for a second, then it kicks back to life after dropping down 1,000 rpm or so and climbs happily to redline. Who knows, maybe a new calibration would do the trick, but either way it's irritating as hell and it's happened about 5 times so far.
Old Nov 21, 2005 | 02:42 PM
06black's Avatar
so its not just me
dude that happend to me only wayyyyyyy worse i was driveing home on I-75 doin about 80 and all of a sudden my tach just stoped it droped down to 0 when my spedo still read 80 and the car was most def still on cuz i was still driveing....so i pulled over shut it of than started it agen and still nothing after i let it set for like 10min i started it and every thing was fine but thats happend 2 times now and the dealer cant tell me why!
Old Nov 21, 2005 | 02:51 PM
3fo893013L's Avatar
Stop whining you little bitch , Just kidding man, where you taking it to? Don't tell me the Dealership in Lake Orion... they just suck all together.
Old Nov 21, 2005 | 02:57 PM
Although your problem is a serious issue in it's own right, it's a bit different from what myself and a few other have experinced with our SS/SC's. What happens to me is not a tach malfuntion, but a hiccup in the fuel/spark when at high boost/rpm's. It completely shuts the power off like you hit the rev limiter and dumps you down from 5,500 to 4,500 then continues climbing again like nothing was wrong. Only problem is, the motor is no where near the rev-limit when this is happening.
GM...you SUCK!
Old Nov 21, 2005 | 10:37 PM
Action Jack's Avatar
Don't worry about it too much. For a week straight my car did the same thing about 4 times in one week. That was when I only had my K&N, but after that week it hasn't done it since. It hasn't even done it with my psi-fi kit. Hopefuly your's will go away on it's own like mine did.
Old Nov 22, 2005 | 01:33 AM
well my friend took his redline in today , atleast 1 plug was bad the ground electrode was gone
had the p0300 missfire code set
well tonight it started acting up again , it started loosing power under boost about 90mph , i went for a ride with him the cel started flashing , and stayed on , and lack of power about 70 now , and just before you get into boost
he bought the car last week , with 37k on it , its still under the dealers 90day , plug he got a extended policy , im thinking something in his is hurt badly
he is taking it back this week , and droping it off so that they actually have time to look deep into it
Old Nov 22, 2005 | 09:42 AM
06black's Avatar
awww shizle all you do is BITCH! lol man i'm goin to wally edgar i take it there for every thing and alway fix it rite...so back it goes!
Old Nov 22, 2005 | 09:37 PM
Shermen's Avatar
mine SS/SC has done that one time but it was in 2nd gear and it just like died and i put it back in first and poped the clutch and it started right up and the check engine light went off like 50 restarts and 2 hours later it was running fine. but durning thost 2 hours i cluldnt go past like 25 mph. and i had to go through like all 5 gears. is seamed like it was running on only 2 cylinders.
