big problems help help help
Old Jul 12, 2007 | 10:55 AM
brett5's Avatar
i was driving down the highway today in 4th gear and had a wide open lane so i figured i'd get on it so i down shifted into 3rd slamed the gas and at about 4500 to 5000 rpms the whole car like stoped like i redlined it the rpm guage fell to 0 but the car was still on and running but not very well it was chugging along...no CELs or anything at this point.. got off the highway almost came to a stop and car stalled.....so i popped the hood no sign of anything wrong tried to start it and wouldn't turn...tried again a couple mins later and it started and i drove it home with no problems ran fine right now i have it sitting in my driveway with the hood popped and the battery disconnected...what the hell just happened ????the rpm gauge worked on the way home and the clutch was still there????/
Old Jul 12, 2007 | 11:03 AM
Acidangel_5.0's Avatar
something fugged up and ecu killed the car.. its all good.. its a safety feature
alleycat58's Avatar
So it was at 4500 to 5000 AFTER or BEFORE you went into 3rd. I would assume after. That really doesn't seem that rediculously high in 3rd. If it went back to driving fine, you're probably alright. How does idle sound - rough or normal?
brett5's Avatar
did this happen to you????why did the rpm guage go to zero?
Old Jul 12, 2007 | 11:04 AM
alleycat58's Avatar
Was thinkinga bout that as a possibility too. A sensor freaked out and it shut itself down to protect the car.
Old Jul 12, 2007 | 11:05 AM
brett5's Avatar
it run and idles like it did before and i revved a couple time to check it and it seemed fine
while i was in third gear at 4500 to 5000 it did this
Old Jul 12, 2007 | 11:08 AM
pvirga88's Avatar
Never had that problem but I think you should take it to the dealer or a mechanic to get it checked out. That is some crazy ****!!!!
Old Jul 12, 2007 | 11:20 AM
brett5's Avatar
well i hooked everything back up and it seems to run perfectly fine now...sounds just as loud as the loud ecotec sounded before at idle.
Old Jul 12, 2007 | 11:48 AM
Shortbus's Avatar
My old one did that once before also, i downshifted into third and just slamed it, all gauges went down to zero, and the car was barely runing then shut up, but was fine after a minute, wierd.
Old Jul 12, 2007 | 12:02 PM
brett5's Avatar
well at least i'm not the only one thanks guys i feel much better now
06MetallicBalt
Jul 20, 2025 08:47 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
