Bleeding h/e question
Old Sep 19, 2008 | 01:10 AM
theneelster's Avatar
Here's a question I have that hasn't really been addressed on adding a h/e.
I get that bleeding the h/e is necessary to get air out of the system but since the surge tank already has an atmospheric purge near the cap doesn't that mean it's pointless to bleed the system because as you drive the system should automatically bleed itself when the air get's to the surge tank.
Is bleeding necessary or just a waste of time? Someone point out the epic fail in my logic.
Old Sep 19, 2008 | 10:23 AM
williamhvx1's Avatar
get option b setup on top of h/e and dual pass and the system will bleed himself..
Old Sep 19, 2008 | 02:13 PM
ShortStack's Avatar
i think you had it right by saying when u drive it around after the install.. the surge tank went down ALOT!!! in just about 20 seconds of driving...
refilled twice before it stopped moving....
Old Sep 19, 2008 | 04:02 PM
?????? after one drive i refill and that it! it should be bleed. at u sure got a right setup? and bleeding is necessary to use the at max the h/e setup...or if u got a small pulley is mandatory for reliability!
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
