Blower making funny noise under throttle
when ever I go WOT my blower makes this crazy high pitch whining noise like it's gonna fall off ... is that right ?
hahahaha
just playin , I'm freakin bored at work !
hahahaha
wow, you nned to take your girlfriend(blower) to the doctor and have her lungs checked out. There might not be enough teeth in her mouth, causing the loud whistle, id also check to see if she has a glass jaw, good luck
also i dont think its a good idea to put her under the throttle, you may be squishing her. this could cause the loud noise as well.
check the flux compasitor. . .
mine did that for a while and turned out I had a bent johnson rod.. and since that was bent my flux compasitor couldnt reach all 20.9 jiggawatts . . . but now its ok
yeah they repaired my main buffalo wing thats connected to the exhaust off the wickamidu.
hopefully the fireball accuator in cylinder #14 wont act up again, i wasnt pleased when i blew up the semi travelling behind my last week when i opened it up and hit 239 psi at 3500 rmp :O
