Bolt snapped off in header to dp flange
Old Apr 23, 2012 | 08:41 PM
Blinker fluid's Avatar
Hey guys, I replaced my downpipe back to stock, a few days later there was a nasty sputter coming from under the car, come to find out, one of the bolts snapped off in the header flange. Whats my best bet? Drill it out? How hard would that be? input appreciated thanks
Old Apr 23, 2012 | 08:46 PM
Superbalt06's Avatar
Might be able to use an easy out
Old Apr 23, 2012 | 08:52 PM
What is that?? Never head of it, sorry lol
Old Apr 23, 2012 | 08:55 PM
ssyellow's Avatar
LOL I had this same problem Jake. Easy out won't work, not enough space. Spray with PB Blast then use vice grips to wiggle it out. Small pipe wrench worked wonders also because it tightens the more you turn.
Though mine snapped due to being rusted on when I tried to take it off, not sure how you managed to break yours driving.
Old Apr 23, 2012 | 08:59 PM
pb blast, grip the end with the grips and put the pipe wrench over the grips and twist, sounds like a better idea I could of ever thought of. thanks nate! ill let ya know how it goes, ill try it tomorrow
Old Apr 23, 2012 | 09:03 PM
ssyellow's Avatar
Sounds good. And its either pipe wrench or vice grips, not both at the same time haha. I think the pipe wrench is what finally got it out.
Spray PB blast on tonight so it soaks. The more soaking the better.
Old Apr 23, 2012 | 09:05 PM
Future reference this is how a easy out works. Kinda of nice but doesn't work everytime.
Screw extractor | easyout | broken bolt removal - YouTube
Old Apr 23, 2012 | 09:12 PM
I honestly think when I put the dp on, i may have cross threaded the bolt stupid me, usually its easy to tell because its hard to tighten anything you cross thread, but I didnt notice it, i screwed up, if I get it out and its all sheared up, should I just throw a bolt thru it and put a nut on the otherside and douce it in locktight? failure on my part
Old Apr 23, 2012 | 09:15 PM
that looks sick, but I would probably have a 0.00% success rate with that, thanks for the knowledge though, now I know!
Old Apr 23, 2012 | 09:16 PM
I would take it back off and work on it off the car. Makes it a lot easier. I would re thread it a nut on the other side would look tacky in my opinion. Or like you said from the beginning drill it out and tap to the next size bigger.
Old Apr 23, 2012 | 09:17 PM
You think I should remove the header for that? How hard is it to remove that? From what i saw under the car there isnt much room down there
Old Apr 23, 2012 | 09:25 PM
ssyellow's Avatar
Easy out was my first option but I couldn't get it to thread for the life of me, terrible angle there. Grab the stud from the back and use the vice grips or small pipe wrench. Go to the dealer and get a stud and nut there. Its going to run you $12. Yes its over priced but don't be a hack job.
Old Apr 23, 2012 | 09:36 PM
If it were my car I would take off the manifold. Very easy to do if you have a rust free car. Not as easy if it's all rusty. I would pb the studs for the manifold the night before and the next morning take off the manifold. Then get a tap and fix the threads. Once it's off you may be able to grab it with some channel locks or something. Or just drill out the hole and put a nut on the back. Lol it's all up to you. He said he possibly cross threaded it thats why I say he needs to re thread it. Just simply putting a new bolt in won't do much good.
Old Apr 23, 2012 | 09:41 PM
ssyellow's Avatar
PB + pipe wrench worked for me. BUT if its being that big of a bitch then yes taking off the mani is probably best. Will have to buy a new gasket though.
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
