boost backing off
Old Mar 16, 2008 | 10:47 PM
boostking's Avatar
boost backing off
I have an 06 ss/sc with 3.0in, 42s and a zzp tune. When my veh. hits 5,500 rpm my boost goes from 15-17 to 10-12. Is anyone running this kind of setup on there stock exhaust. I have a feeling my stock exhaust is causing to much back pressure at hgh rpm. can anyone verify?
Old Mar 16, 2008 | 10:50 PM
Beck's Avatar
its not your exhaust... superchargers don't work like turbos, the exhaust should be the least of your worries.
sounds like the boost bypass valve is opening, most likely a tuning fix
Old Mar 16, 2008 | 10:51 PM
lsjwannabe's Avatar
belt slip
Beck's Avatar
Originally Posted by lsjwannabe
belt slip
or that.
Old Mar 16, 2008 | 10:53 PM
lsjwannabe's Avatar
are you running a stock belt?
Old Mar 16, 2008 | 11:05 PM
LopsidedJester's Avatar
yup, sounds like belt slip, if you don't have a stage 2 belt or aftermarket tensioner then that may be the problem
Old Mar 16, 2008 | 11:36 PM
rockkrawler628's Avatar
that happens on stock cobalts... the bypass mod will work for this... it supposed to bleed off boost
Old Mar 17, 2008 | 01:19 AM
RedEcotecSS's Avatar
as they said before, sounds like slippage.
Old Mar 17, 2008 | 01:23 AM
ItalianJoe1's Avatar
Yeah, if it was the bypass it would open before it got to 17psi, it wouldn't let it go past 12.5 unless they changed it, and a ZZP tune will have adjusted that.
Old Mar 17, 2008 | 10:16 AM
Area47's Avatar
Rent me! per hour
if the iat2's are too hot. it will back off the boost till it cools down.
check and see if your aftercooler pump is working.
Old Mar 17, 2008 | 01:30 PM
boostking's Avatar
I disagree. the more air coming in the more exhuast needs to leave. this is why all the aftermarket company's are recom. exhaust mods with stage 2,3 etc... but I agree with the fact that the exhuast may not be my number 1 concern because I have raced guys with the same setup with exhaust mods and I pull them. this is why my exhaust has not been changed yet. about the response from area47, I tested your concern. after about 3-5min of warm up I went out and got on the car. 15-17psi to 7k with no concerns with the boost backing off. now I do see boost start to back off after 5,500 when the veh. was been running for more than about 1/2 hour..... I do believe my pump is working because I just put the updated intake and blower gasket on my car and I was able to bleed the aftercooler while the veh. was running,but I will verify. could my mods be to much for my stock cooling system to take? I'm guessing you need a tech 2 or hp tuners to look at your iat2 sensor? please if anyone has heard of this problem let me know. a belt slip is not happening I have a gm shorten belt which was tighter than ***** to get on the zzp 3in.
Old Mar 17, 2008 | 11:24 PM
boostking's Avatar
Originally Posted by thatotherguy
You might have a boost leak. cuz i have the same problem on the dyno. do you have an aftermarket boost gauge that runs into your boost/vacum line??? if not check the hose that goes behind your supercharger under your injectors to your stock boost gauge under your hood you might have a crack or something in that hose.
that can't be the problem. it only happens after the veh. has be running for a while and over 5500k.
Old Mar 17, 2008 | 11:25 PM
thatotherguy's Avatar
im not saying it is but that my guess cuz thats what happen to me. you running a stock belt?
BLAZIN07SS's Avatar
I'm too JDM for you
P.S Has got acquainted with the girl, http://cyberblady.com, how it to you? Only it is fair!
why is this in all of your posts?
Old Mar 17, 2008 | 11:27 PM
im on my brothers computer i dont have one so i gotta use this one. somethings wrong with my comp. but cant find the problem
Old Mar 17, 2008 | 11:36 PM
boostking's Avatar
I don't know what is going but I need to figure it out
DarrenGC
Dec 24, 2021 01:55 PM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
Sep 27, 2015 08:53 PM
OPCrer
Sep 27, 2015 08:11 PM
