boost bypass
Old Jul 19, 2005 | 07:10 PM
clownhair's Avatar
Originally Posted by zinner
I got it all hooked up today and I can't tell any difference. I still don't get to above 11 PSI on the boost guage. I am 99% sure it's grounding properly at WOT. Must be no more boost to give
I will see how it works with a 3.25 pulley once mine arrives.
no more boost to give report back when you have the 3 1/4 on.
Old Jul 19, 2005 | 09:47 PM
zinner's Avatar
Moderator Alumni
Hurry up USPS!
Old Jul 19, 2005 | 09:54 PM
carbombss's Avatar
Hurry up USPS!
took mine 4 days so relax
Old Jul 20, 2005 | 12:01 AM
zinner's Avatar
Moderator Alumni
Ok I reconnected my ground wire and I am definetly hitting 12.5 (indicated) on the guage.
So maybe it helps. I am not ready to totally dismiss it now. Can't wait to see how it works with a pulley upgrade.
Old Jul 20, 2005 | 01:27 AM
ToMeGuN's Avatar
Glad to hear bro
Would like to see what kinda times you would get with the mods ya have done. Keep us posted!
Old Jul 20, 2005 | 12:07 PM
Maven's Avatar
TIPS ON TESING CIRCUITS
A mulitmeter is a great tool, however it is not the always best tool.
A acircuit that only has one strand of wire will test good for continuity and will hold the full voltage the vehicle makes(12-15volts) HOWEVER.......it will not hold the amperage required to do any work.
A simple test light made out of a halogen headlamp bulb will never let you down when it comes to verifying if youve got power or if youve created a proper ground. This test light will draw up to 10amps so be sure to never use it on any functioning circuit, control module OR ANY YELLOW wiring harnesses or connectors(airbag system)
Old Jul 20, 2005 | 01:42 PM
jem's Avatar
jem
SO let me understand, with this mod you can hit 12.5 PSI sooner or all the time or what?
Old Jul 20, 2005 | 01:47 PM
dj4all's Avatar
And without getting a CEL???
Old Jul 20, 2005 | 03:17 PM
Maven's Avatar
This will allow you to use whatever boost level the supercharger is making any time the circuit you create is completed.
Old Jul 20, 2005 | 03:20 PM
Maven's Avatar
While it is highly unlikely that under normal cicrcumstances this mod would set a check engine due to the small amount of time most engines spend in the highest throttle positions it is obviously possible to set a code under certain instances or if you set the bypass "bypass" mod to engage too soon or all the time.
Old Jul 20, 2005 | 03:30 PM
  #36
dj4all's Avatar
Would this cause warranty issues should something fail becuase of the tinkering?
Old Jul 20, 2005 | 04:05 PM
  #37
ray@revitup's Avatar
im going to attempt this week to wire this to one of the chanel signals on the emanage. since the emanage works with tps, well not on the cobalt of course due to drive by wire but we use accelerator position. (hint) i think i can set this up so that once you hit wot the emanage will turn off the bypass.
Old Jul 20, 2005 | 04:06 PM
  #38
no switches all electronic
Old Jul 20, 2005 | 04:25 PM
  #39
zinner's Avatar
Moderator Alumni
Originally Posted by ToMeGuN
Bummer man I would rig something just a temp back to the battery ground and give it a shot ? Sucks if that doesnt work.
I think the point of the WOT throttle switch is so it's not ground 100% of the time.
Old Jul 20, 2005 | 04:46 PM
  #40
Maven's Avatar
Only if the dealer A: even notices this mod if you do a professional install B: if they can PROVE this mod caused issue you will have to pay for the repairs required, your warranty however is very difficult(nearly impossible) to get voided.
Old Jul 20, 2005 | 04:47 PM
  #41
Maven's Avatar
Thats awesome Ray, be sure to let me know how it works
Old Jul 20, 2005 | 04:56 PM
  #42
dj4all's Avatar
Can someone post a How To if this ends up working. If not, maybe some pics on what wires need to be relocated and how - sorry for sounding dumb but this is all Greek to me (no offence to the World Cup champs)!!
Old Jul 20, 2005 | 05:03 PM
  #43
Maven's Avatar
Originally Posted by Maven
IF your going to attempt to modify this system or its operation YOU DO SO AT YOUR OWN RISK, AND RISK POSSIBLE UNWARRANTIED ENGINE DAMAGE
With that said here is what you should do to modify this system.
Splice into circuit 1724(grey) from Supercharger Bypass Solenoid. Run the spliced in wire to a normally open single pole single throw micro-switch mounted on a bracket under your instrument panel and mounted in such a manner that the switch is closed with by the throttle pedal somewhere in the 80-100% range(based on your prefernce). Attach a wire to a verified good ground and then to the open terminal on the microswitch.
This modification will force full boost under all conditions when the switch is depressed and still allow full PCM control of boost under all other operating conditions.
Thats as How-to as I can get. Maybe Zinner or someone else can post pics.
Old Jul 20, 2005 | 05:04 PM
  #44
Maven's Avatar
And what do you mean if it ends up working????
Old Jul 20, 2005 | 05:08 PM
  #45
dj4all's Avatar
I have all the faith in you guys to make this project a reality. I'm just not clear on what it is you're trying to ultimately achieve. Are we looking for the same amount of boost, only sooner so as to cut down 1/4 mile times? Are we looking for MORE boost as to generate more HP - which is good for bottom and top end? That's all I'm trying to figure out.
Old Jul 20, 2005 | 05:09 PM
  #46
zinner's Avatar
Moderator Alumni
When I tapped in the boost soleniod wire I pulled back the loom and tapped into it about 4 inches down from the plug. Replaced the electrical tape and you wouldn't know it's even there unless you were troubleshooting that specific connection/part.
If it works out I am going to run the wire back the pedal a bit better however.
The only think you are going to see on mine is the lever switch and I found a good push button switch that I might be able to hide even better.
Old Jul 20, 2005 | 10:27 PM
  #47
clownhair's Avatar
I might try your way out this weekend. See if the car behaves.
Old Jul 22, 2005 | 12:01 AM
  #48
zinner's Avatar
Moderator Alumni
Well just to update the thread so it doesn't get lost in the shuffle. I got the pulley and tool today from SFPH. I am going to install it some time this weekend I hope. Need to get some anti seize from the parts store.
Old Jul 22, 2005 | 12:11 AM
  #49
MarcS's Avatar
The Stig
Good news, keep us posted
Old Jul 22, 2005 | 12:28 AM
  #50
zinner's Avatar
Moderator Alumni
Has anyone already installed the DUB system on their SS/SC and care to give me some tips
Tips like: Did you find away to put on the dub without taking the supercharger off?
