boost bypass
Old Jul 22, 2005 | 01:26 PM
  #51
clownhair's Avatar
Originally Posted by zinner
Has anyone already installed the DUB system on their SS/SC and care to give me some tips
Tips like: Did you find away to put on the dub without taking the supercharger off?
if its like the redline your going to have problems getting the puller to clear the alternator and tensioner. The SC is realy simple to take off. Its just 4 hex bolts. It will take 2 people to compress the new pulley on. Make sure your grease the sc shaft before putting the dub unit on.
Old Jul 26, 2005 | 01:27 AM
  #52
zinner's Avatar
Moderator Alumni
Well I got the hub unit on the shaft tonight, going to put it back together tomorrow.
clownhair I didn't put any grease on the shaft of the supercharger but it went on pretty easily,
I didn't figure anything like that would need grease since it's not supposed to slip.
Old Jul 26, 2005 | 03:24 PM
  #53
zinner's Avatar
Moderator Alumni
Got the pulley finally installed and the supercharger back on. I have noticed a difference in how fast the car makes the boost, but the guage doesn't read any higher than before. I am starting to doubt the gauge a bit, might look into a mechanical boost gauge.
Old Jul 26, 2005 | 04:41 PM
  #54
MarcS's Avatar
The Stig
I think the computer is still bleeding off at it's normal limit. It will make boost faster because it's a smaller pulley but you still won't make 14 psi because of the PCM.
Old Jul 26, 2005 | 05:03 PM
  #55
clownhair's Avatar
yeah the electronic boost guage is going to need to be replaced. You are definately hitting higher boost now. Spend 50 bucks on a guage and tell us what it says.
Old Jul 26, 2005 | 05:04 PM
  #56
clownhair's Avatar
nope it will make 14 psi there has been a confirmed issue with the CSS guages not reading higher than 12 psi.
Old Jul 26, 2005 | 05:15 PM
  #57
MarcS's Avatar
The Stig
Oh ok, it's just the gauge that wont read that high then. I did read that the gauge was also limited by the PCM which would make a mechanical gauge a better choice for accuracy.
Old Jul 27, 2005 | 04:17 PM
  #58
zinner's Avatar
Moderator Alumni
FYI:
Pulley is installed and working great.
I did a little write up.
https://www.cobaltss.net/forums/how-guide-43/pulley-swap-howto-4054/
Old Jul 27, 2005 | 11:51 PM
  #59
zinner's Avatar
Moderator Alumni
I just got my manual today and the 1724 gray circuit goes into ground. So how is grounding a circuit at WOT keeping the bypass closed?
I am confused ... Is the ground on that circuit switched ?
Old Jul 27, 2005 | 11:57 PM
  #60
zinner's Avatar
Moderator Alumni
Nevermind I looked at page 6-671 in the manual
Old Jul 27, 2005 | 11:59 PM
  #61
MarcS's Avatar
The Stig
Good question, I would imagine that the switch opens the connection to the ground which disables the circuit. However, the switch has it's own ground.. so isn't that redundant? lol I'm confused. I need to see a diagram.
Old Jul 28, 2005 | 12:04 AM
  #62
zinner's Avatar
Moderator Alumni
the circuit goes into the PCM and the PCM must unground or disable the circuit to bleed of boost.
Old Jul 28, 2005 | 12:07 AM
  #63
MarcS's Avatar
The Stig
So when the circuit is closed or enabled is when the bpv allows boost?
That makes sence then, the switch just ensures a ground.
Old Jul 28, 2005 | 12:14 AM
  #64
zinner's Avatar
Moderator Alumni
We must not let Maven know we questioned him :-p
Old Jul 28, 2005 | 12:17 AM
  #65
MarcS's Avatar
The Stig
Old Jul 28, 2005 | 08:04 AM
  #66
Maven's Avatar
told ya'.
Old Aug 23, 2005 | 02:12 AM
  #67
99_civic_si's Avatar
Please check out my post in this thread https://www.cobaltss.net/forums/show...ed=1#post54045
It does what you guys are looking for, but without the ill side effect of having to "trick the pcm" It's honestly the way the system should work, but car companies are trying to make cars idiot proof against breakage. I'm sorry but if they design somthing to cut the boost if it detects drivetrain abuse, it has to be bypassed if you want to race and have fun. I will be doing what I explain in the post sometime this week. I KNOW it will work, and I'll ease everyones mind about it in a week or 2.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
