Boost Gauge???
Old Aug 25, 2008 | 04:37 AM
Blown 4-banger's Avatar
Boost Gauge???
Don't even think about calling me a noob or I will come to your house and slap you silly. I searched, and found nothing I needed. I need pics of the vacuum line you "T" off to the gauge. I put the T on the line that comes off the manifold under the fuel rail, but I'm pretty sure thats not right unless my car idles at almost ZERO vacuum (which I guess with my cams that is a possibility). I just want to make sure I'm getting an accurate boost gauge reading. Heres proof I searched, and found no threads (with pics).
I'll have to bump it in the morning, non of you late night ***** know anything
Last edited by Blown 4-banger; Aug 25, 2008 at 04:37 AM. Reason: Automerged Doublepost
Old Aug 25, 2008 | 05:27 AM
hungryhip-ccp's Avatar
thats the right line... its the only one that has manifold pressure!
Old Aug 25, 2008 | 08:15 AM
Doc's Avatar
Doc
someone post a pic for the n00b
Old Aug 25, 2008 | 10:31 AM
rrutter81's Avatar
Where mine is hooked up. Im using the Prostreet 2 boost guage
Old Aug 25, 2008 | 12:42 PM
Tennpenn83's Avatar
noob...
Old Aug 25, 2008 | 01:00 PM
Area47's Avatar
Rent me! per hour
newb.
the single vacuum line comming out of the intake manifold.
t into it before the sensor.
Old Aug 25, 2008 | 01:11 PM
Omega_5's Avatar
Originally Posted by Area47
newb.
Sensor?
Do you mean the OEM bypass actuator?
Old Aug 25, 2008 | 01:56 PM
rrutter81's Avatar
there is a boost sensor that sends the signal to your guage after the t-fitting...or so i thought. Lot of wires there to just be a bypass.
Old Aug 25, 2008 | 01:59 PM
Area47's Avatar
Rent me! per hour
Originally Posted by Omega_5
Sensor?
no. i ment sensor.
it does multiple things actually
Old Aug 25, 2008 | 05:36 PM
Well ****! I guess that means I'm idling at like 3-4 inches of vacuum, and make 4-5 psi boost at 1/2 throttle. ****. No vacuum = cams.
Old Aug 25, 2008 | 09:38 PM
Texas SS's Avatar
noooooooooob lol
Old Aug 25, 2008 | 10:19 PM
theneelster's Avatar
Car shouldn't idle at 0 vac, regardless of the cams you have in.
Old Aug 25, 2008 | 10:21 PM
ItalianJoe1's Avatar
How agressive are the cams??
Sounds more like a messed up gauge though, or a vac leak. Thats too low.
Old Aug 26, 2008 | 04:28 AM
Most cars with redonkulous cams have problems with low vac at idle.
Old Aug 26, 2008 | 04:39 AM
mrsilent13's Avatar
my guess would be a leak.....cuz ive never seen vac that reads 0 and only boosting 4lbs
Old Aug 26, 2008 | 09:38 AM
Josh@ottp's Avatar
ya thats way low for vac at idle. whats it read like on decel in first gear at say 20mph?
Old Aug 26, 2008 | 11:20 AM
Decel first gear at 20 mph is ~18-20 inHg of vacuum. Also I've had it up to ~12 psi boost.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
