boost gauge issue
boost gauge issue
got the new gauge aqll hooked up useed all brass fittings instead of plastic (all i had) all plumed with pipe dope and what not and sealed tighttt,,, now when i go in boost the guage will go up and if i hold it on boost the guage will start to go down what could the issue be???
Then I would say **** it and now worry about it lol
Or get an scangauge and use the boost readings off of that or go back to your stock gauge
Maybe it's not the gauge.
AKA check into bypass solenoid or boost bypass valve? One of the threshold's in my tune was causing boost to drop off at redline, we quickly fixed that though.
Do this to check, it's free-
https://www.cobaltss.net/forums/how-...ass-mod-11994/
idk where u pulled urs through at, but i had a hell of a time getting mine.. luckily i got it the first try but I was extremely careful with it.. but I used the plastic fittings that came with mine.. then I black taped the crap out of all of it. check all of it and make sure it's not pinched no where.. if not that, then I go back to saying that it's got a hole in it...
no fittings came with mine so i made a t fitting out of all brass fittings but if i put to to 5 psi and try and hold it there the gauge drops slowy to 0 when i know im making boost
if you can't feel a power drop, then it's something in the hose.. put a plastic "T" on it and black tape it so that it don't come off.. then make sure that it's not 'pinched' anywhere.. if it's still not working after that, you need some new hose.
how do u know it's not leaking? if it's not leaking, then that means you got a hole or something in the hose.. I'd just hope for the bad brass fitting instead of having to run a new hose through the firewall..
