boost gauge issue
Old Dec 4, 2010 | 12:22 AM
DEZZIE41's Avatar
boost gauge issue
got the new gauge aqll hooked up useed all brass fittings instead of plastic (all i had) all plumed with pipe dope and what not and sealed tighttt,,, now when i go in boost the guage will go up and if i hold it on boost the guage will start to go down what could the issue be???
Old Dec 4, 2010 | 12:50 AM
DEZZIE41's Avatar
lsj's help please
Old Dec 4, 2010 | 01:07 AM
Glowbalt's Avatar
maybe it's snagged somewhere on the line? loose fitting?
Old Dec 4, 2010 | 01:08 AM
DEZZIE41's Avatar
fittings are all nice and tight i dont see a snag any where
Old Dec 4, 2010 | 01:29 AM
DEZZIE41's Avatar
Old Dec 4, 2010 | 09:15 AM
mrbelvedere's Avatar
a bad guage
Old Dec 4, 2010 | 10:50 AM
DEZZIE41's Avatar
bumpppp
Old Dec 4, 2010 | 11:00 AM
DEZZIE41's Avatar
some one must know
Old Dec 4, 2010 | 11:08 AM
troyss's Avatar
Can't be really nothing else other then a BAD gauge or the hose is crimped somewhere... Nothing else can be wrong
Old Dec 4, 2010 | 11:09 AM
DEZZIE41's Avatar
so if i change the guage or check my linw and its not either or then what would u say do
Old Dec 4, 2010 | 11:21 AM
DEZZIE41's Avatar
could it not be working right cause i had to use brass to make my t fitting???
Old Dec 4, 2010 | 01:31 PM
troyss's Avatar
Then I would say **** it and now worry about it lol
Or get an scangauge and use the boost readings off of that or go back to your stock gauge
Old Dec 4, 2010 | 07:22 PM
Joe Schulte's Avatar
Maybe it's not the gauge.
AKA check into bypass solenoid or boost bypass valve? One of the threshold's in my tune was causing boost to drop off at redline, we quickly fixed that though.
Do this to check, it's free-
https://www.cobaltss.net/forums/how-...ass-mod-11994/
Old Dec 4, 2010 | 07:24 PM
DEZZIE41's Avatar
im going back to stock nothign is working
Old Dec 4, 2010 | 07:26 PM
troyss's Avatar
That mod is stupid IMO and does it only work if your on a small pulley since it stays on 15lbs and don't drop to 12?
Old Dec 4, 2010 | 07:29 PM
DEZZIE41's Avatar
im selling everythign noe stock gague here i come yet again
Old Dec 4, 2010 | 11:07 PM
DEZZIE41's Avatar
could it be becuase that i have to much 1/8 hose just laying around and need to cut it?????????????????????????????/
Old Dec 4, 2010 | 11:11 PM
corn-popSS's Avatar
your boost should be climbing the longer that your on the throttle.. I'd say that you got a little leak in the hose from where you pulled it through the fire wall.
Old Dec 4, 2010 | 11:14 PM
DEZZIE41's Avatar
u think so i cant c it it is think 1/8
Old Dec 4, 2010 | 11:19 PM
corn-popSS's Avatar
idk where u pulled urs through at, but i had a hell of a time getting mine.. luckily i got it the first try but I was extremely careful with it.. but I used the plastic fittings that came with mine.. then I black taped the crap out of all of it. check all of it and make sure it's not pinched no where.. if not that, then I go back to saying that it's got a hole in it...
Old Dec 4, 2010 | 11:21 PM
DEZZIE41's Avatar
no fittings came with mine so i made a t fitting out of all brass fittings but if i put to to 5 psi and try and hold it there the gauge drops slowy to 0 when i know im making boost
Old Dec 4, 2010 | 11:25 PM
corn-popSS's Avatar
if you can't feel a power drop, then it's something in the hose.. put a plastic "T" on it and black tape it so that it don't come off.. then make sure that it's not 'pinched' anywhere.. if it's still not working after that, you need some new hose.
Old Dec 4, 2010 | 11:27 PM
DEZZIE41's Avatar
i had the same issue last time with a diff guage but y go to plastic when my brass fitting is tight and it is not leaking
Old Dec 4, 2010 | 11:30 PM
corn-popSS's Avatar
how do u know it's not leaking? if it's not leaking, then that means you got a hole or something in the hose.. I'd just hope for the bad brass fitting instead of having to run a new hose through the firewall..
Old Dec 4, 2010 | 11:31 PM
DEZZIE41's Avatar
iy only took me like 3 min to run the hose through the firewall
