Boost Gauge not working
Old Jul 17, 2006 | 12:24 AM
JamesTabs's Avatar
Sorry if this was posted/asked already but I noticed that my boost gauge is always at 0psi.. even when i hit the gas or redline it...it never moves...is there something that I can do to fix this? Or is this how it is supposed to be?? I have no clue..any help would be great.
Thanks in advance
Old Jul 17, 2006 | 12:40 AM
X3r0's Avatar
take it to the dealer
Old Jul 17, 2006 | 12:42 AM
Rangerondubz's Avatar
umm yea def suppose to be about 20 vacumn and about 12psi at full throttle redline....you def have a bad connection somewhere prob at the sensor....take that **** to the dealer
Old Jul 17, 2006 | 04:21 PM
JamesTabs's Avatar
thanks.. i figured it was a loose connection..i made an apt. for wed. we'll see how it goes
Old Jul 17, 2006 | 04:25 PM
selfinfliction's Avatar
save yourself some time and pop off the pillar first, all that holds it on is one screw and it snaps right out. check the back of the gauge to make sure that the connector didn't pop off. it'll take less than five minutes and it's worth a shot if it might save you a couple hours at the dealer
Old Jul 17, 2006 | 04:30 PM
Tomtwtwtw's Avatar
Do your wipers still work? If not then check your fuse box...found out while fiddling with my car this past weekend that they run off the same fuse.
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
