Boost levels with 2.85 pulley ?
Old May 31, 2007 | 12:45 AM
c24na's Avatar
Hey guys,
with the 2.85 i see anywhere from 15 to maybe 18psi. Will log it with hpt in the next few days. Was expecting to see a pound or two less w/catles 3" dp and 3" mid exhaust, but installed the stage 2 and exhaust at the same time. So i have no reference point.
What kind of boost levels are some of you seeing with 2.85 or others.
Thanks,
Nate
Old May 31, 2007 | 12:47 AM
peck05's Avatar
with my stage 2 and a 2.79 pulley im getting 17.5 psi
Old May 31, 2007 | 12:51 AM
ptrblkz24's Avatar
Ditto
Old May 31, 2007 | 12:07 PM
Area47's Avatar
Rent me! per hour
im running 1.06 bar on a stage 2 pulley
16 psi on a 2.8
header back exhaust helps a lot!
Old May 31, 2007 | 12:11 PM
Toronto SS's Avatar
I see 16 to 17 psi depending on the wether with my 2.86
Old May 31, 2007 | 12:14 PM
Sunburst_SS's Avatar
I'm seeing right around 18 psi w/ my 2.85
Old May 31, 2007 | 12:32 PM
Acidangel_5.0's Avatar
17-18 with 2.9
Old May 31, 2007 | 12:37 PM
SSdan's Avatar
17-18 on 2.8. Cold winter nights I pin my boost gauge.
Old May 31, 2007 | 12:55 PM
wallas06SS's Avatar
This is probably a dumb question but does having an exhaust give you more psi?
Old May 31, 2007 | 12:56 PM
JCswoosher2's Avatar
my full 3" did not
Old May 31, 2007 | 12:57 PM
wallas06SS's Avatar
Originally Posted by JCswoosher2
my full 3" did not
Isn't 3" too big for our cars unless you are over 300 HP?
Old May 31, 2007 | 01:08 PM
no.. exhaust will drop it normally because you will have better flow
Old May 31, 2007 | 01:17 PM
CTCOBALTSSS's Avatar
With my mods (in the garage) and a 2.9" pulley I saw 16.69psi @ 6,800rpm while getting tuned. HPTuners said so. lol
Old May 31, 2007 | 02:48 PM
Area47's Avatar
Rent me! per hour
depends on what you're doing with the car.
psi is a measurement of resistance.
if you open something up, like the exhaust as a whole. you will lose psi, but gain efficiency
Old May 31, 2007 | 03:13 PM
SSdan's Avatar
IE, you will still move the same amount of air, just alot more free flowing.
Old May 31, 2007 | 03:15 PM
barryBlueSS's Avatar
2.93 pulley...boosting 17.2 with Hp tuners!
Old May 31, 2007 | 03:29 PM
BlackSS/SC's Avatar
2.6" PULLEY, seeing 16psi
Old May 31, 2007 | 03:34 PM
jester's Avatar
I have a 2.8 and usually see around 15-16
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
