Boost Limited in 1,2?
Old Nov 22, 2006 | 08:38 AM
Gonzo2007's Avatar
I just got a new Cobalt SS and it seems just as fast in third as second. Is the boost limited in first and second gears? Do the stage kits remove this limiter?
Old Nov 22, 2006 | 08:42 AM
3fo893013L's Avatar
Boost is not limited to 10psi in first gear I beleive.
2nd and 3rd have no limitations.
Old Nov 22, 2006 | 08:47 AM
StinkBOMB's Avatar
How many miles are on the car? Mine didn't show full boost until around 1000 or so. And there is some factory torque management in 1st gear, but not 2nd that I know of. You kinda need it for 1st gear, as that gear provides the least amount of traction.
Old Nov 22, 2006 | 08:50 AM
BlackyK's Avatar
Least amount of traction? How about NO traction in first lol. My first on-ramp experience with my SS/SC was truely orgasmic. But I had to short shift into 2nd, the wheelspin in 1st was insane.
Old Nov 22, 2006 | 08:53 AM
Gonzo2007's Avatar
I just rolled over a thousand KM. So what should my max boost in second and third be? 10 or 12 lbs? Thanks
Old Nov 22, 2006 | 08:58 AM
StinkBOMB's Avatar
Depending on altitude 10-12.5 psi. Some members have posted their boost level is lower because of air density. I would give it more time than 1000km. Some people boost to the max right away, and some take time to acheive full boost.
Allshot's Avatar
You should be boosting 12
Old Nov 22, 2006 | 09:01 AM
StinkBOMB's Avatar
^^Too early to tell, as posted I didn't boost to 12 until I had around 1000 miles on it. He could just need more miles on the car.
Allshot's Avatar
I also thought you had to break in the car to see more boost but I found out that was wrong. If you go WOT you will only see 10PSI of boost but once you go over 5500-6500 Rpm's you will see it slowly climb to 12. The hard thing to do is watch your boost gauge and your rpm's becasue you dont want to hit the rev limiter. Go out and check this out and it should work.
Old Nov 22, 2006 | 09:04 AM
Allshot's Avatar
This was written to me when I first joined this site and I thought I had the same problem. It worked for me.
Originally Posted by CTCOBALTSSS
OK here's the thing. If you punch it in say 2nd gear at 3,000rpms. You will see around 12psi for a couple thousand rpms. It's when you reach 6,000 and 6,800rpm that the boost finaly reaches 15psi. So it's not what happens in the begining it's what happens at the end if you know what I mean. You have to go all the way to or near the rev limiter to see the full boost. Common mistake. No worries.
Old Nov 22, 2006 | 09:08 AM
StinkBOMB's Avatar
Maybe that's the case. I was kinda worried too when I first got my car so I had someone watch my boost gauge while I was accellerating and he told me he only saw 10. His Cobalt also did the same thing for the first thousand miles or so. And yes the charger will see 10psi before is sees 12 as it needs rpms to do it, but that doesn't mean someone didn't watch all the way to red line.
Old Nov 22, 2006 | 09:09 AM
StinkBOMB's Avatar
Perhaps we should establish whether or not the OP actually took his car to redline and watched the gauge?
Old Nov 22, 2006 | 09:17 AM
Allshot's Avatar
Ya. I had 1200 miles on mine when I did this and It worked for me. It climbed really slow to 12 it didnt just jump from 10 to 12 all the sudden.
Old Nov 22, 2006 | 09:42 AM
SS_Canuck's Avatar
I never have a chance to look at my boost in 1st gear, not enough time before I am shifting to 2nd.
Old Nov 22, 2006 | 09:50 AM
cds00bsmg's Avatar
HPTuners allows you to limit boost in first gear. (all gears I think). If you get it tuned, I think it should be limited to 5-6psi once you start doing modifications, in order to increase traction, etc. I rarely try to see any boost in first, it just roasts the **** out of the tires.....
Old Nov 22, 2006 | 09:55 AM
Allshot's Avatar
He was asking if the car limits the boost in stock form. He thinks his boost isnt 100% in first in second gear.
Old Nov 22, 2006 | 11:08 PM
Gonzo2007's Avatar
So....apparently i am an idiot. I live in canada and my gauge is in kpa. 80 kpa = 11.5 pounds or so. I did not even look at the units. sorry guys
Old Nov 23, 2006 | 01:58 AM
rukkee's Avatar
The more miles i put on my car the more boost it produced up till 12.5 when stock . My theory is that the cat starts to get more deposits in it, causing more restriction, therfore showing us more boost. I could be totally wrong , but its an idea.
Old Nov 23, 2006 | 02:05 AM
chipmonk212121's Avatar
the older a ar gets the more buildup there is in the SC housing. but that wont happed after 1,000 miles. mine has ALWAYS shown 12.5 lbs of boost from 2nd gear on at the top RPM. I am at about 400-600 feet elevation at all times. i do believe that somewhere from GM it states 12.5 lbs of boost@ 6500 RPM. My boost will not break 0 in 1st or neutral no matter what.
RaginChopsuey
Oct 27, 2015 01:27 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
