boost problems with a 2.8, need help.
the hiss is probably from the dp... are you catless? And if you went to the 2.8 and 3" dp at the same time thats probably why you are at the same boost as before because your flowing a little better... as for it not feeling as quick... you are probably just used to it already and now you want more
I'm at 14-15 psi with my 2.8. It used to be at 16-17 with the stock exhaust setup. Now I'm running a bad mab header and zzp 3" dp. You being at 15 psi sounds about right with your mods.
se i have a 3' catted zzp dp that i installed at the same time as my 2.8 and it read 18psi, and now its 15 soild, one guy said that its my zzp pcm doing it, its cutting me back to 15psi, so he said dynotune it and it will be back to 18psi
It just doesn't make sense that it was 18psi for a month then it dropped to 15 over night, like I said i was at 15 psi on a stage 2 pulley, 3.0 in, now I have a 2.8 should be at least 17 psi, does anyone know if the is a certain torque sequence for tge intake bolts? Cause it could be that I put them in out of order...
dude i have a boost leak tester, and i used it, i HAVE 2 leaks, one is somewhere by my super, and the other sounds like it is toward the back of the motor, so get over your self, my gauge is right on, it read 17-18 for a month, the gauge is fine, that and i have no power, and runs rich as hell, cause a stock cobalt can keep up with me, like right on my bumper, it has a problem!
i dont know for sure where it is, insofar as the one in the back i can hear a hiss but can't find it, so i was hopeful that someone would have an idea what part by the trans back by the brake/clutch res. would be leaking, that and i put all new gaskets in the intake, so i must have not installed/bolted them down right, so do they have to be torqued in a certain order, or does that intake to block have to face a certain way, because i did it to the best of my ability, and it worked for a month, so that's my problem.
When I installed my ZZP Long Tube Header/Catted Downpipe I went from 17 psi to 15 psi boost. Though some of that could be just because I was heat soaked, but I did expect a boost DROP and HP INcrease. Less restriction means lower boost and MORE power to the crank, because the engery isnt being used up pushing the exhaust out as much.
hey
hey man i got the same thing going on with my balt.. my friend has the exact same car as mine except he has the high flow cat and the zzp true 3'' intake.. ill post more laater, at work. but i hope you figure it out. i used to boost 16 psi solid creeping up to 18 @ 7300RPM.. DID MY 3" exhaust, couple day later cant go past 15psi..
my buddies car same thing, but with larger intake and high flow cat, and he pulls away from me everytime, 16psi at the punch and it creeps to 18.. we both have 60s with 2.8" pulley. stage3 zzp kit and everything.... soooooooo idk but ill post more later.
problem is nothing u have told me i didn't already know, intake + exhaust = less boost more power because it is less restricted....duh i get that i'm telling u that with my intake and exhaust it was still at 17-18psi(at 65 degrees outside), now at any temp its 15-16psi, and a power loss, cause i have a leak or two, so i will re-due my intake cause the gasket is bad or backwards or not torqued right w/e, i heard the leak! and then i shall post pics if it get it squared away, i know for a fact my car is less powerful then it was when i installed my ****!
