Brake fluid problem
Old Feb 6, 2012 | 12:55 PM
rekameohs_nire's Avatar
Brake fluid problem
About 5 months ago I had an issue where everytime i would stop hard or go around a corner my brake fluid light would come on. I thought it was wierd but just filled it up and had no issues with it again, until now. It was doing the same thing as before so i bought brake fluid and filled it up. Next day it starts doing it again so I look for spots under the car and any leak anywhere and cant seem to see anything. But about everyday I have to fill the brake fluid. Anyone have any ideas??
Old Feb 6, 2012 | 04:16 PM
G11's Avatar
G11
Could be a couple of things...could be tob leaking or master cylinder leaking.. check all of your calipers to make sure they ar e good.
Old Feb 6, 2012 | 04:34 PM
ok. and also when i pump the brakes the pedal gets softer and softer and my interceptor reads like 30 misfires
Old Feb 6, 2012 | 04:47 PM
red06SC's Avatar
I had the same problem, It kept getting low every week or so.
My solution was more fluid.
Hasn't lost any in a year or so...
Old Feb 6, 2012 | 04:51 PM
K-Train04RL's Avatar
Check ur calipers for leaks also when doing this bleed ur system. If ur calipers are dry and all the air is out of ur system the clutch is also using the same res
Old Feb 9, 2012 | 12:11 AM
how long did you add before it stopped?
Old Feb 9, 2012 | 12:33 AM
Pepsi's Avatar
Check the rear calipers. They usually start leaking
Old Feb 9, 2012 | 12:36 AM
just checked and it is both rear calipers. why do they leak. how can i fix them
Old Feb 9, 2012 | 02:55 PM
SaberD's Avatar
stop by your local auto parts store and tell them to order you a couple caliper rebuild kits. each kit is only about 8 dollars.
The rebuild kit comes with a new square cut seal, dust boot, and snap ring.
remove the brake line from the caliper and plug it.
remove the e-brake cable
remove the caliper and drain it
remove the caliper slide bracket
remove the dust boot and piston, then remove the sqare cut seal from the piston
thoroughly clean the piston and cylinder
replace the square cut seal on the piston
lubricate seal and cylinder with brake fluid and reinstall the piston
install the new snap ring inside the dust boot and use a mallet to tap on the new dust boot.
reassemble
...or you can spend hundreds on new calipers.
There are several things that can cause a caliper to leak:
-overheating detroys the square cut seal
-old broken down brake fluid does not lubricate as well, and will cause excessive wear on the square cut seal
-contaminated brake fluid can scratch the cylinder walls and destroy the square cut seal
-a torn dust boot can allow contaminants into the cylinder causing scratches on the cylinder wall and destroying the square cut seal
When rebuilding your calipers, inspect the bore to make sure the inner surface is not scratched. If it is, then you will need new a new caliper, and you can return the rebuild kit.
rokon340's Avatar
My driver side caliper started leaking not long ago,just got a replacement caliper at advance auto for about 30 bucks.On my 2006 ss.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
