BRAKE pads and ROTORS>
Old Feb 21, 2012 | 12:11 AM
SaberD's Avatar
Ceramic pads are your rotors' worst enemy!!!!!!
They are the hardest pad material you can get. the number 1 determining factor of rotor life is the hardness of the pads. The only reason why you would get ceramic pads is to reduce brake dust. However, you do it at the cost of performance, and at the cost of the life of your rotors.
i use organic or semi metallic pads. they don't last as long and create more dust, but they stop harder and dont wear your rotors as much. I'd rather be replacing pads than rotors anyways. its a lot less expensive that way, and takes less time. some food for thought...
Old Feb 21, 2012 | 12:12 AM
Leafydialupking's Avatar
Honestly I've never had a GM car newer than the 80's that didnt need rotors every time it needed pads no matter what pads you used. Not to mention I always see and hear the exact opposite about ceramic pads, carbotech are by far the best pads you can get for most cars off the shelf and they are mostly ceramic pads.
Old Feb 21, 2012 | 12:13 AM
nhanson's Avatar
Whats a good organic or semi metallic pad?
Old Feb 21, 2012 | 12:19 AM
SaberD's Avatar
that is because the dealership and brake shops are usually liars. I've had multiple shops tell me I needed new rotors when I just put new ones on 6 months ago on several occasions.
Hawk HPS are some of the best pads you can get for the street. Although pads from the auto parts store are nearly as good. You won't notice a difference unless you road race the car. I just bought some store brand pads from NAPA when i got my rotors there.
Old Feb 21, 2012 | 12:28 AM
A good pad for what? Are you daily driving? Is it trailered to the track? How much do you want to spend?
If you are daily driving I would avoid race pads, and any organic and metallic pads like the plague. They require more heat, are touchy, normally corrosive to your wheels, and in general eat through themselves and rotors like nobodies business. Oh yeah they're loud.
If you're going to the track, EBC Yellow's or the correct carbotech pad for your applicaiton.
If money is no object and you're on the street with it, carbotech street pads, they last forever, your rotors will last forever, they dont dust, they're not an on/off switch like the hawks, and good luck glazing them. Of course thats what you get when you pay 189 dollars per axle for brake pads.
I change my own brakes and I measure my rotors, they always end up half way or all the way to the service limit (depending on car and pads). Then after getting them turned they'd be well below. Of course I'm used to cars with rotors that cost under 20 bucks so it costs the same to replace them as getting them turned.
HPS pads aren't bad for the street, but why get them when you can get less dust and better brake modulation with the EBC reds?
Old Feb 21, 2012 | 12:32 AM
nhanson's Avatar
yes daily driving with occasional track use. Im still on stock rotors and pads for a 2.2 and they fade A LOT. 67k miles so im sure its due for a change soon.
Old Feb 22, 2012 | 10:09 PM
turbosmart4's Avatar
im still confused on what to get... well made my mind on rotors (slotted) but havent made my mind on pads...
Old Feb 22, 2012 | 11:03 PM
Powell Race Parts's Avatar
I suggest you shop delco advantage ceramic pads and rotors, not slotted, but well priced, try CED. good value good stopping power and good overall day in day out performance. did i say inexpensive?
So contact crate engine depot they may be able to help you with delco stuff. I find it very good for the price, certainly works well on my wntr btr, way better than the other cheap stuff.
here is the link to try for acdelco stuff good luck
http://www.oempartsdepot.com/Default.aspx
Old Feb 22, 2012 | 11:17 PM
Home Page
thanks! illcheck it out!
Old Feb 27, 2012 | 08:12 AM
I just went over the thread once again and you guys gave me good info , thanks
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
