BRAKE pads and ROTORS>
Old Feb 14, 2012 | 11:18 PM
turbosmart4's Avatar
Question BRAKE pads and ROTORS>
after many days of searching and reading on past threads i finally came to a conclusion. i first started off with the idea of buying drilled and slotted rotors , but i read many threads about them braking.... then i thought about getting slotted only.. but they eat pads... and after that i wanted dimpled rotors, but they are pricey and perform the same as stock ones... so i now want to buy plain rotors but high quality... who sells nice plain rotors? other than stock...brembos maybe?
Old Feb 15, 2012 | 12:57 PM
Leafydialupking's Avatar
Stock plain rotors. as long as they're the same thickness and within tolerance for runout they're all going to perform about the same. It's the pads that'll make the difference. EBC reds should be perfect for these cars or an aggressive daily sometimes racer.
Old Feb 15, 2012 | 01:03 PM
rectorc08's Avatar
Duramax Gold.
Old Feb 15, 2012 | 01:05 PM
I'D SECOND EBC but i couldn't get them. my hawk hps are holding up god so far, and no fade. no waviness on my r1 concepts rotors either
Old Feb 15, 2012 | 01:14 PM
jg707's Avatar
i bought some plain rotors from R1 concepts. good price, think it was like 130-140 for the pair. they are the temp treated ones with coated center hubs so it doesn't get rusty. haven't put them on yet but they look quality.
EDIT: I have an LNF with the brembo's btw not sure what you have.
Old Feb 19, 2012 | 10:18 PM
i just read these posts, thought no one would answer lol
Old Feb 19, 2012 | 10:21 PM
heathkidder's Avatar
why would drilled and slotted rotors break?
Old Feb 19, 2012 | 10:24 PM
the holes make them weaker
Old Feb 19, 2012 | 10:26 PM
soooo i shouldnt waste the money. maybe some 1 with them will chime in.
Old Feb 19, 2012 | 10:29 PM
MastaShaKe_88's Avatar
I literally JUST got a full set of OEM Rotors & Hawk HPS brake Pads from Modern Performance.. well I got the rear pads from Amazon Got a good deal on all of it tho
Old Feb 19, 2012 | 10:30 PM
nhanson's Avatar
Drilled rotors are going to heat up faster and will eat pads.
Stick with plain.
Old Feb 19, 2012 | 10:32 PM
dont buy them, im between plain and slotted
how much are they selling rotors for? R1 sells them for 110 a pair or so.. drilled, slotted, or plain
Old Feb 19, 2012 | 10:34 PM
well this changes my mind about them now hmm ill have to look around more
Old Feb 19, 2012 | 10:35 PM
NGASales's Avatar
we offer a great set of blank rotors that work well.
We can package them with EBC or Hawk pads
Not a whole lot.. Ima check my receipt, but you coooould always jus go to their site lol It'd be cheaper for you cuz you dont have to get the Brembo rotors
Old Feb 19, 2012 | 10:39 PM
pm me
Stick with plain.
im staying away from drilled rotors lol
what are your package deals, ?so far R1 is the most economic
yea true, im gonna check in a bit, good thing theyre located in houston , so shipping is cheap/// i think
Old Feb 20, 2012 | 04:02 PM
SaberD's Avatar
NAPA premium rotors are the best deal for quality blank rotors. This is the most common choice among road racers.
I painted my napa premiums with vht high temp clear, and after 6 months, still no rust and they are still shiny. I masked off the braking surface before I painted them. I abuse the hell out of them and still have no pulsation. I use organic pads with them too. Stay away from ceramics if you want good braking performance and want your rotors to last.
Old Feb 20, 2012 | 10:23 PM
i thought ceramic was rotor-friendly
Old Feb 20, 2012 | 10:33 PM
Ceramic is rotor friendly, it will glaze over though if you over heat it, it also makes for less dust and quieter brakes. Its one of the reason I went with the EBC's over the Hawks. If I glaze the brakes I can always fix that, cleaning the corrosive dust off the wheels constantly from the hawk hp+'s is just a pain.
Old Feb 20, 2012 | 10:43 PM
09BlueBaltSS's Avatar
R1 has standard and a higher grade iron option for the rotors. I wanna say regular is like G3000 and premium is G3500
Old Feb 20, 2012 | 11:15 PM
would slotted rotors help de-glazing? im thinking of getting hawk ceramic pads
so all the rotors they sell are high grade , or u have to getthem in special order?
Old Feb 20, 2012 | 11:16 PM
I dont think it would. The heavier rotor would normally help glazing because its due to too high of a surface temp on the pad. Brake ducts would stop the glazing.
Old Feb 20, 2012 | 11:23 PM
so its a good combo then?
Old Feb 20, 2012 | 11:39 PM
For R1 e-line is the lower grade, premium is higher grade
