brake squel
Old Oct 23, 2009 | 09:14 PM
DEZZIE41's Avatar
brake squel
shes got new pads and turned rotors the dealer did this about 3 months ago and now there squeling all the time wtf?>
Old Oct 24, 2009 | 03:34 AM
Zach06CobaltSC's Avatar
Could be warped rotors, some stock cobalt rotors had an issue with this.
Old Oct 24, 2009 | 09:54 AM
buellfooll's Avatar
Warped rotors won't cause brake NOISE. But they WILL cause a pulsing sensation in the car and, depending on the severity, will feel it in the pedal. They will also cause premature wear on the pads. To prevent warped rotors be sure to TORQUE the lugs to 100# in a cross pattern. Take them to 60-70# then to 100#, do them all, then go around one more time. Unless the rotor went on the car new already warped, by using this procedure you'll never have a warped rotor again and you'll get better braking and longer life. Or better yet buy a "torque stick" which limits the torque to the rated amount. They are available in many socket sizes and torque ratings. It's used on your impact and you just ram the lugs home till the stick stops turning. It's bvetterif you tighten the lugs somewhat before torqueing. You'll get 100#, within 10# every time. Personally I like to go around the lugs one time with the torque wrench after the impact. So many shops think the best way to putn a wheel on is to ram them home till the impact stops turning. Possibly 150# PLUS. And they go around once one right after the other. This is my experience and with the knowlege of many upscale and professional tire and wheel installers. It works!
Old Oct 26, 2009 | 08:12 PM
stonny9's Avatar
How many threads are you gonna start!!!!!!!! Please search
Old Oct 26, 2009 | 08:15 PM
boost_junkie16's Avatar
I see the ban stick coming out
Old Oct 26, 2009 | 08:17 PM
DoMiStIc_RuSh_06's Avatar
lol...i think someone is trying to get their post count up...lol
Old Oct 26, 2009 | 08:19 PM
stonny9's Avatar
not on me look how long I have been here. He had 4 threads on the first page alone and has only been a member here 1.5 months
and I dont care about my post count look how low it is
Old Oct 26, 2009 | 08:35 PM
outtamymind's Avatar
if the pads and rotors are brand new chances are the tech forgot to lube the brake pads connecting points
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
