Brand New Car + Boost Question?
Old Sep 30, 2005 | 09:59 PM
2K5SS/SC?'s Avatar
Well, the dealership finally came to my terms on a fully loaded 06 Silver SS/SC, so i picked her up today!
I have 200+ miles on the car already, and it is great! The only problem is the boost gauge only showed 3 LBS when I tried to get on it. Granted the car hauls A$$, but the gauge doesn't reflect it. Is my gauge defective or do I need to give it time?
I've read the posts about the stock gauge being inaccurate, but I would like to know if this is normal for the first "X" amount of miles. Thanks guys!
Old Sep 30, 2005 | 10:03 PM
MarcS's Avatar
The Stig
It should be reading closer to 10lbs for the first 1400 miles or so. I would take it in and point it out to them.
Old Sep 30, 2005 | 10:06 PM
2K5SS/SC?'s Avatar
Ok, sounds good. That's what I thought. Just wanted to check with you guys.
Old Sep 30, 2005 | 10:15 PM
ExHondaMan's Avatar
Domestics Pwn
What gear and rpm is that in ? When I was stock in 1st gear the highest it would go was 5psi.... I think becuase the gear ends so quickly the gauge cant keep up... Then it second near redline it would read all the way up to 10.5psi...
Old Sep 30, 2005 | 10:21 PM
MarcS's Avatar
The Stig
My gauge would not go past 5# in 1st initially and I contaced GM about it. I took my car for a drive the next day to test it again and I hit full boost.
Not sure what caused the change, I assume I was not hard enough on it.
Old Sep 30, 2005 | 10:52 PM
zinner's Avatar
Moderator Alumni
In 2nd gear at 3000 and above I am almost always at 10 psi +
Old Oct 1, 2005 | 02:59 PM
2K5SS/SC?'s Avatar
Got 5 PSI today! That's a little better. I'll give it some more time!
Old Oct 1, 2005 | 04:31 PM
97cavie24ls's Avatar
i test drove 1 , and it was hitting 12 psi in every gear , car had 7 miles on it , before i beat on it
and same with the redline drove it was in the 12 psi range also
best would be to hook up a mechanical boost gauge up and see if yours is off , if it is take it in to get looked at
Old Oct 3, 2005 | 05:34 PM
2K5SS/SC?'s Avatar
Great News! I popped the hood for my buddy to look at and I was examining the vacuum line that everyone says to check. As I ran my fingers along the line I noticed that the electrical connector going to the small black box that the vacuum line runs from the bypass valve to and then to the manifold was not connected at all! I plugged her in and now I have my 12 PSI! I also unleashed the animal in the car too! It is so freaking fast now it's scary! I guess I was hardly boosting at all since I test drove the car! Needless to say I had to check my boxers after that ride!
Old Oct 3, 2005 | 05:37 PM
DJNateGnau's Avatar
Dumb electrical connectors.
Old Oct 3, 2005 | 06:49 PM
mikekoz's Avatar
HAHA that's hillarious.
Old Oct 4, 2005 | 11:35 PM
plyboy-illest's Avatar
i ahve 3,000 on my SS\SC and im egtting 10 psi the delaer told me to wait till 5,000 KM and if im not gettign the 12.5 then they will chek it out
Old Dec 25, 2005 | 10:32 PM
Doc's Avatar
Doc
Canadian should hit 86 kpa to equal 12.5 psi....(somewhere near there).....take it easy giving it a few spirited kicks (a few is like not many ) and it should run like a champ.
my .02 cents
Old Dec 25, 2005 | 10:33 PM
Doc's Avatar
Doc
1200 miles and 12.9 psi
Turbo Johnny
Feb 21, 2019 09:41 AM
yellowsupercharged06
Sep 17, 2015 04:40 PM
twilson380
Sep 14, 2015 10:52 AM
CobaltSS 16
Sep 6, 2015 02:04 PM
