Budget...
Old Feb 27, 2007 | 04:52 PM
Theas1an's Avatar
Budget...
If i were to lets say...be on a budget.. would it be cheaper to go straight to stage 2? or should i do stage 1... or is stage one not even worth doing(as in no difference over stock)
Old Feb 27, 2007 | 05:23 PM
Stouffer's Avatar
Save up the extra $165 and get the stage 2
Old Feb 27, 2007 | 05:35 PM
D4u2s0t's Avatar
woth the wait for stage 2...
Old Feb 27, 2007 | 05:37 PM
chevysalesman614's Avatar
stage 1 is good, if you wanna go smaller than the stage 2 pulley at some point.
stage 1 gives you like 30 horses, but not really any torque. stage 2 gives more hp than stage 1, by adding more boost.. this in turn gives you torque
i think the claimed #'s are
stage 1: 235hp / 200tq
stage 2: 241hp/ 218tq
i really have no opinion on what one to get, since i decided to go aftermarket. but i hope the facts help you.
p.s. check out the STAGE KIT *sticky* at the top of the tech page
Last edited by chevysalesman614; Feb 27, 2007 at 05:37 PM. Reason: Automerged Doublepost
Old Feb 27, 2007 | 05:39 PM
Ljavy17's Avatar
stg 1 doesnt give you any power or tq. lol. Just the ability to put on a 3" pulley and if you want a 2.8.
Old Feb 27, 2007 | 05:57 PM
ignore this post. the injectors, and the new stage 1 tune will definitly give you SOME power. maybe not a whole lot though
Old Feb 27, 2007 | 08:59 PM
cblt12's Avatar
if you want to save and also want a lil more power than stg 2, just get stg 1 and a 2.9
Old Feb 27, 2007 | 10:45 PM
05redline's Avatar
Is it even enough to give an noticeable amount of power?
Old Feb 27, 2007 | 10:48 PM
Coblt ss super's Avatar
arent the tunes between stage 1 and stage 2 differnet tho? thats what i have heard before
Coballsnation's Avatar
100% ^^^
Old Feb 28, 2007 | 01:49 AM
rukkee's Avatar
Nope they are the same . I bought stage one and it came with stage 1 and 2 instructions . It said if you have already done the stage 1 flash that you can skip to the next step in the stage 2 installation procedure.
Old Feb 28, 2007 | 02:11 AM
Theas1an's Avatar
ah, ill look into doing the stage 1 and then upgrading from there. thanks guys!
Old Feb 28, 2007 | 08:16 AM
good so now this is going to let me do stage 1 and then get a 2.9" pulley and put that in, now when i go to the dealer to get a reflash what do i tell them?
Old Feb 28, 2007 | 08:28 AM
SKDR112888's Avatar
I got a question If I piece together my own stage kit can I still get the GM reflash tune?
Old Feb 28, 2007 | 04:03 PM
ReMz's Avatar
nope
Old Mar 2, 2007 | 09:26 PM
rukkee's Avatar
Nothing , just tell them you want your stage one flash and then go home and put the 2.9 on . I suggest putting it on afterwards just incase they want to test drive it or something stupid .
I bought stage one and then bought a used stage2 pulley and hub, even with the special blue bolts and socket , my car runs great not even a hiccup.
Old Mar 3, 2007 | 01:15 AM
but the flashes arnt differnet? i mean they are running 2 different boost levels, so wouldnt the car run more lean?
Old Mar 3, 2007 | 09:26 AM
RaineMan's Avatar
No... the flashes are the same... it allows for 15PSI at peak power.... if your car won't make 15PSI b/c of still running the stock pulley... the ECU isn't gonna give it all the extra fuel it needs to compensate for increased boost.
Just like you can get the car to redline without being on the throttle hard enough to get into boost. The ECU is only gonna add fuel for the airflow it detects.
Old Mar 3, 2007 | 05:29 PM
oo so what if it goes over 15psi? its not gunna throw enough fuel or its gunna get an error right?
Old Mar 3, 2007 | 05:55 PM
CHARGDSS's Avatar
Watch ebay for the stage 2 kits....i bought one for 350+15s/h. had no problems getting it installed. Then i bought a 2.8 pulley. I hit 18psi no problem now
r0k0
Nov 10, 2007 01:17 PM
