View Poll Results: What mod should i do next?
CA Header
5.45%
DP with high flo-cat
5.45%
Vibrant, or magnaflow cat back
7.27%
Save your money for stage 2 kit!
45
81.82%
Voters: 55. You may not vote on this poll
Build my car
then go with vibrant race headers 4-2-1 + downpipe. and finish it off with a nice catback of your choice
and from what i've heard on the CA header, its the same size collector as stock so the gains would not be as good as a nicely crafted header with a 2.5-3.0" collector would be idea if you plan on doing a full exhaust set up
well personaly i've always done it this way. make it breath right,and make it run cool then throw in the injectors and boost. but maybe i'm doing it wrong... i hade no idea that the collector was the same size.. thats kinda gay. Would the vibrant 4-2-1 bolt up to the stock DP and would the stock header gasket work if i went to GM and bought a new one before i installed it? or do they send a gasket for the block and DP with it?
Crate Engine Depot has a good Mid Winter sale goin on right now you can pick up a GM perfomance cat back real cheap along with stage kits and the dual pass intercooler.
You might want to check it out.
if funding is tight you could always go with the CA header and downpipe though. supposidly CA saw a 10hp gain i believe from their header on a 2.4L SS. Still not bad, but imo the collector is still a little small.
https://www.cobaltss.net/forums//showthread.php?t=38201
check this thread out for more info on the header. that supporting vendor sells them, not sure of the price. But i havnt really looked around anywhere else for them. I only drive a 2.4 and debating a turbo so header/dp will not be coming anytime soon
the size of the collector should depend on which DP you plan on going with and how much boost you plan to run, not to mention power output and RPMs should be considered also. bigger isnt always better
well thats good to know lol... yeah i think i may do that... any other views?
