Buying ott stage 1 need help
Old Feb 13, 2009 | 02:13 AM
TheSandMan's Avatar
Ok so im about to buy the Stage 1 but there is a few things i dont know. 1- should i remove torque management? 2- should I get the belt or tensioner pulley?3-what should i set redline to 7000,7200,7400?4- should i keep stock TB or go with the LS4 TB upgrade?
Old Feb 13, 2009 | 02:17 AM
fzn14's Avatar
1.) yes
2.) Gm stage belt FTW
3.)7000
4.) you can keep the stock TB but it would never hurt upgrading
Old Feb 13, 2009 | 02:18 AM
blk ss/sc 1's Avatar
^x2 and just keep the stock TB except if u have extra money to waste.. u dont need to upgrade though
Old Feb 13, 2009 | 02:19 AM
TheSandMan's Avatar
sweet thanks, do you have the kit?
and i was wonderin the same thing for when i order.. what exactly is torque management... and what happens whenu remove it?
~Mike~'s Avatar
I'm personally gonna have wicked toon mine and get the limiter set at 7200 so when i go to shift at 7k i don't bounce on the limiter. I'll never take it past 7 k tho. agreed with fzn14, upgrades don't hurt, but not necessary and gm stg 2 belt will work perfectly.
Old Feb 13, 2009 | 02:20 AM
ordering mine next friday
Old Feb 13, 2009 | 03:01 AM
fzn14's Avatar
I personally have the kit and have had it for about 7-8k now. Thus that being said...My stock times for the track are....14.2...With OTT stage one, catless DP, TTR tranny mounts, And the canned tune they send you...13.8 LOL
Old Feb 13, 2009 | 03:04 AM
TheSandMan's Avatar
really only .4 s i thought you get a lot more power from it...how much horse power and psi do you run with it
Old Feb 13, 2009 | 03:11 AM
lsjwannabe's Avatar
Track times are a tricky subject really. You could have different temps, different DA, different prep. Lots of things effect the outcome that being said i have seen people run 13.4 on our kit well some run 14.4, it all comes down to the driver.
Old Feb 13, 2009 | 03:13 AM
TheSandMan's Avatar
so whats the power look like from stock to stage 1 about how much does the HP and psi change?
fzn14's Avatar
well for its being 90 degrees and being in MO i thought it was a good time...I was on the stock tires as well if that makes any huge difference lol, Either way i couldnt be happyer with my kit, And its cool cause every other mod i add like I/E/DP etc etc my car keeps coming more and more alive
Old Feb 13, 2009 | 03:16 AM
lsjwannabe's Avatar
Bone stock your around 205~210 whp 12.5 psi
OTT stage 1 your around 245~250 whp 17.5 psi
Old Feb 13, 2009 | 09:01 AM
06SS ALL DAY's Avatar
nobody answered that doods question about what torque management. i know what it is but i cant explain **** right i always leave **** out
Old Feb 13, 2009 | 09:04 AM
ShortStack's Avatar
The second post answered the question about removing the torque managment... which you should remove...
i would use a 7250 redline anyway.
Old Feb 13, 2009 | 11:07 AM
lsjwannabe's Avatar
Tq management is just the computers way of limiting power before after shifts slightly.
Old Feb 13, 2009 | 04:31 PM
TheSandMan's Avatar
just ordered it, F**k i cant wait.
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
