C/A Heat Exchanger Install ?
Old Apr 17, 2009 | 11:28 PM
QuickSilver_SS's Avatar
Post C/A Heat Exchanger Install ?
Well, i did a fair amount of searching and found qwight a few threads on heat exhangers in general. I have a cobalt addiction heat exchanger i got off of a local member. I'm hoping to hook it up over the weekend. But i don't really know where to hook the hoses up to ?
I have a home made option B hooked up right now that i will probably have to remove. My main questions are. Where do the two hoses go from the new heat exchanger ? To the top or bottom of the end plate ? The pump ?
I would love to run both heat exchangers together. Is that what most have done ? And my last question is , Will i have to bleed the system after words ? If so, how would i go about that ?
Thanks for any help and input ! At this piont i've got myself kinda confused !
Old Apr 17, 2009 | 11:44 PM
cobalt ss/sc's Avatar
get on zzperformance.com they have real nice diagram of how to run it, yes u will have to let the system bleed air
Old Apr 17, 2009 | 11:54 PM
Thanks for the help man, it looks like from that diagram i can run both h/e together. But i guess from the looks of it i will have to re-install my factory filler neck. I don't mind that. I wouldn't mind having it to check once in awhile to see if my pump is still working. So how am i going to bleed the system of air ?
And as nice as that pic is , are the zzp h/e and the c/a h/e the same ? I can never tell when im under my car which line from the stock h/e is the in and which is the out !
Old Apr 18, 2009 | 01:23 PM
Bump !!!!!
Anyone know ??? It looks to me like i have to hook one end of the h/e to the pump and the other end to the right hand side ( if your looking at the front of the car ) of the stock h/e. Is that right to run both together ? And if so , how have any of you guys bleed the air out of it ?
Last edited by QuickSilver_SS; Apr 18, 2009 at 01:23 PM. Reason: Automerged Doublepost
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
