C/X racing h/e installed w/pics
I installed the H/E physically to the front end but did not route the coolant lines yet. It got dark and I was getting bit by too many mosquitoes. I thought i would share what it looks like. It is about a quarter inch lower than i measured but I left it out of impatience.
This is the smaller cx racing h/e. fyi.
I started to. but then came to my senses and bent some aluminum. I was trying to install it like the one that was posted a couple days ago but could not fit a drill between the bumper and the radiator w/o a right angle drill. I instead bent a couple pieces of aluminum and made a quick bracket with bolts and called it a day. No need to remove anything.
Did not cross that bridge yet. I just test fitted everything and am tackling the rest thursday when I get off work. Now that all of my fitting is done it should be simple to do the rest.
I bought it off ebay a few weeks ago it should be about $150ish from the username cxracing on ebay. Then maybe $25ish for miscellaneous parts from lowes/menards or wherever.
should of gotten the bigger one
ebay. $149
here is my how to guide to install the bigger one that takes up the whole front open part.
https://www.cobaltss.net/forums/how-guide-43/how-install-mount-big-cx-heat-exchanger-124669/
simple and great mod for less than $199 bucks all said and done after taxes shipping and other tools needed
