CA H/E fitmit question.
Old Dec 24, 2007 | 11:48 PM
RedEcotecSS's Avatar
So me and Sunburst_SS had my front bumper off today. Got the L brackets drilled and everything's going well. Only issue is the braded hose will not fit onto the coolant pump. I tried for about 2 hours getting it on. Simply seems like the braded hose provided by CA is too small... Any ideas? Thanks.
Old Dec 24, 2007 | 11:57 PM
chevysssc's Avatar
its not a little grease and muscle will do it it took me 1 hr of being pissed to figure it out
vasaline works good
Old Dec 25, 2007 | 12:05 AM
This might sound crazy but this is what i was thinking of doing if all else fails. I would use the first 'curve' of the stock hose where it connects from the pump to the stock IC. i'd cut it off enough to put it on the pump then i would take some plumbers 'hose connector' thing and connect the cut piece of stock hose to the CA hose.... do that with both ends.. whatcha think??
Old Dec 25, 2007 | 12:09 AM
06REDSS/SC's Avatar
It is a P.I.T.A. to get it on there, but it is possible.
I took a little propane torchand heated the inner rubber in the braided line until it was pretty warm, which will make it a little more forgiving, then just force the damn hose on there. I also rubbed a little bit of motor oil inside the hose and on the coolant pump, because "lube is always your friend"
Old Dec 25, 2007 | 12:12 AM
hatrickstu's Avatar
yea that was our biggest problem on my buddies car, just drink some beer and keep trying
Old Dec 25, 2007 | 12:16 AM
any comments on this?
Old Dec 25, 2007 | 02:45 PM
Sunburst_SS's Avatar
easiest way......how it was done on Robs car.......it'll save alot of cussing and headaches.
Old Dec 25, 2007 | 11:17 PM
was it really done that way on Rob's car? didnt realize that..
Sean Cummings
Jan 8, 2020 10:17 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
