CA stage 3 question
CA stage 3 question
i was thinking about upgrading from gm stage 2 to CA stage 3
after i get the header an downpipe
but on the site it says Stage #3 : 2.7 ZZP Interchangeable Pulley system , 1 step colder ngk IRIDIUM spark plugs , GM shortened belt , 42# Lucas Injectors , Injector Wiring Harness, Stage #3 Retune ... Est. 65 Hp over stock - 18 psi boost
i was just wondering if 2.7 with 42# injectors r safe??
and the arguent ... 2.8 with 42's is really ok as long as you're tuned properly.. if you have a commanded afr of something rediculous like 10.8 then yes you will be killin the injectors..
I ran a 2.8 on 42's for a while.. know poeple running a 2,.7 on the gm stg II tune,., is it a good idea... NO.. but for some reason the cars haven't blown up yet
read my post... it was a typo
Last edited by 06blackg85ss; Feb 19, 2007 at 12:42 PM. Reason: Automerged Doublepost
you can either do on of two things.. lean it out to @12.6 or increase timing at the same AFR by a few degrees... but only do one or the other.. .not both.. or watch your motor go bye bye
Iceberg
Sep 29, 2015 12:33 PM
