cam pos sensor
Old Jun 15, 2009 | 07:13 AM
mrbelvedere's Avatar
cam pos sensor
whats the easiest way to put a cam pos sensor housing on so that way you know it is time
Old Jun 15, 2009 | 08:13 AM
jr racing's Avatar
you have to time the actual cam sensor, there should be a mark on the lobe tha goes into the cam and the housing line them up then install with cylinder 4@ top dead center on compression
crank sensor
Old Jun 15, 2009 | 09:28 AM
how i timed it the first time was from the build book ill try this so put #4 at tdc compression put the relucter slot at 4 oclock and slide it to the hex
Old Jun 15, 2009 | 10:46 AM
freakta's Avatar
i did it wrong twice and the car just starts hard now
Old Jun 15, 2009 | 04:23 PM
jr racing's Avatar
1.Rotate the crankshaft until number 4 piston is at top dead center (TDC) on the compression stroke
2.Align the timing mark on the housing with the timing mark on the hex shaft
3.Install the camshaft position sensor housing
thats all you'll need to do buddy
Old Jun 15, 2009 | 07:24 PM
freakta's Avatar
i keep getting tdc wrong its seems to be not on the compression stroke, i dont have a tester so i just felt for it to push up air and did it that way hahaha one day ill fix it, until then it just cranks a few more times until it starts
Old Jun 15, 2009 | 07:30 PM
Edubs's Avatar
You just have to be careful w/ that cause you can f*ck up the security module. Dealership did it to my car, lol...
Old Jun 15, 2009 | 07:32 PM
coopn8r's Avatar
No your putting #1 on TDC probably which is your problem!
#1 is TDC and you can tell by looking at the cam gears, the intake side is pointing at 2oClock and the exhaust side is at 10oClock.. THAT IS #1.....
#4 is when they're at TDC and the Cam gears are not in the position I described.
Old Sep 27, 2009 | 07:51 PM
cobaltguy889's Avatar
so....whats the best way to set it? (sorry for bring it back from the dead)
Old Sep 30, 2009 | 05:30 PM
rik1083's Avatar
sorry for co-signing the revival and going off topic :P
I want to use a cobalt lsj cam sensor on my L61 as I'm using a standalone ecu which can't read the L61's compression sense thingy. I realise it's on the exhaust cam and the L61 exhaust cam is short but I'm actually using a saab head and cams (long like the LSJ).
Could someone explain a little about how the cam sensor connects to the cam? I read somewhere about hex drive, but also something about needing to be "pressed on".. If anyone has some photos of it that would be great
BTW, I'm in europe before you ask why I'm using this engine configuration
Old Apr 13, 2010 | 10:24 AM
here you go tom
Old Apr 18, 2010 | 10:28 PM
here
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
jmelton327
Sep 26, 2015 10:04 PM
