cam sensor
Old Apr 25, 2011 | 12:25 PM
harryresh's Avatar
cam sensor
i swapped the cams in my LSJ for comp cams stage 1. getting a code for the cam sensor. anybody know how to set up the cam sensor. i did it once before. a shop told me #4 piston TDC, line up the marks on the sensor, stick it in. this worked for me last time but no luck this time...
Old Apr 25, 2011 | 04:44 PM
mrbelvedere's Avatar
#4 cylnder tdc on compression stroke
what i do is screw in compression guage rotate engine by hand and when the engine starts to build compression i keep an eye on the guage and the timing marks on the cover and balancer and when the guage peaks line up the timing marks then line up the marks on the cps housing instal and your done
Old Apr 25, 2011 | 06:53 PM
harryresh's Avatar
i did that with no luck. im wondering if ZZP welded in the hex for that sensor in the wrong position
Old Apr 25, 2011 | 06:55 PM
could have
Old Apr 26, 2011 | 12:41 AM
InfraRedline's Avatar
Im having the same **** lol. I have pulled it out and rotated it one notch a few times. Damn sensor likes to turn to easy though so its hard.
Old Apr 26, 2011 | 01:18 AM
06SS ALL DAY's Avatar
are u tom?
Old Apr 26, 2011 | 02:10 PM
harryresh's Avatar
Originally Posted by 06SS ALL DAY
are u tom?
no
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
jmelton327
Sep 26, 2015 10:04 PM
