Can some one finally clear this up for me?
Old Nov 5, 2008 | 11:52 PM
adamo41188's Avatar
Ok. I want S2 but i also want a smaller pulley n 60's ( 60's for later when i go smaller pulley ) so my question is, can i get S2 and throw on 60's and a 2.9?
or.. am i just stuck wiht getting a regular S2, or getting a custome tune?
hope this isnt to confusing. im not the best writer lol
Old Nov 5, 2008 | 11:54 PM
EXsoccer1921's Avatar
just go ahead and get the 2.9 and 60s and custom tune
Old Nov 5, 2008 | 11:58 PM
CobaltSS 16's Avatar
dont get stage 2... just get 60s, pulley of your choice, stage 2 belt, and a tune.
Old Nov 5, 2008 | 11:59 PM
R&C_rallySS's Avatar
exactly
Old Nov 6, 2008 | 12:04 AM
adamo41188's Avatar
Do i need something to tune my car wiht or can i just go to a Dyno n get it done? and will i be able to tune back to stock if i have to for warantee reasons?
Old Nov 6, 2008 | 12:08 AM
Silv3r's Avatar
I think you've got it around the wrong way. S2 is a GM package that contains 42lbers, smaller belt, smaller pully, and a canned tune.
If you were to get a 2.9, you could add that to the S2 to balance out the a/f, but don't go any smaller as a 2.9 is close to maxing IDC's (going over max means you're not pumping enough fuel for the amount of air your engine is drawing).
If you want a 2.9 and 60's, you need a custom tune as well as the stage 2 belt (zzp and some other vendors sell em cheap), and to get the S2 and then do this would be redundant, not to mention expensive.
If you're looking for non-warranteed power, I'd get the 60's, 2.8, a Heat Exchanger and possibly meth, and then fix it all up with a nice tune. It'll blow a s2 away.. well maybe not by a huge amount, but you'll be able to pull a s2 easy.
Old Nov 6, 2008 | 12:11 AM
Good advice. If you would just be happy with stage II, it would be covered under warrinty if the dealer installs it. Well, dealer did not install mine and still said they would keep my warrinty. I paid them 1 hour labor just to look over my work and everything checked out fine. Then they flashed it.
adamo41188's Avatar
^ all my questions answerd! thanks
Old Nov 6, 2008 | 12:18 AM
Silv3r's Avatar
Good good, hope it all works out for you!
Oh and if you decide to go S2 with a 2.9, get the S2 from www.crateenginedepot.com and 2.9 from www.smoothflowpulleys.com. Both are supporting vendors on this site.
I'll be getting a 2.9 and S2 in the spring, I have the money for the custom ****, but I still have 5 years and 100k worth of warranty left
Old Nov 6, 2008 | 12:11 PM
ShortStack's Avatar
ott stage 1 comes with 60s, tune, 2.8 and the belt and such...
For just about less than the s2...
Old Nov 6, 2008 | 04:59 PM
brandondrecksage's Avatar
a lot less, their kit is 450 and gms is 550.
Old Nov 6, 2008 | 05:01 PM
HackAbuse's Avatar
You have to get custom tuned to run 60's and a 2.9
06MetallicBalt
Jul 20, 2025 08:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Trav3480
Sep 28, 2015 02:46 PM
