can u say pauls turbo 2.0
Old Nov 26, 2007 | 06:00 PM
  #1176
Area47's Avatar
Rent me! per hour
Originally Posted by victory_red_SS
You thinking of anyone in particular???
it would be cool if you sent me some stock stuff
lol
we all have our dreams
Old Nov 26, 2007 | 06:04 PM
  #1177
glockglade's Avatar
Keep up the good tuning area 47 you are an invaluable member here..
Old Nov 26, 2007 | 06:09 PM
  #1178
2K5SS/SC?'s Avatar
Paul, you are my hero bro. Damn nice numbers!
Old Nov 26, 2007 | 06:21 PM
  #1179
06blackg85ss's Avatar
lol... wasn't directed at you man.... but.... hahahaa
thanks man. there is definitely more left in her, just need a better BC and a new turbo....
Originally Posted by SilverSS/SC
Nice #'s Paul . Its cool to see both u and Area getting some of the puter stuff solved .
thanks man, it's hasn't been an easy ride, but I think I got her pretty dialed in, just one little rich issue down low I need to clean up, just really haven't had the time.
Last edited by 06blackg85ss; Nov 26, 2007 at 06:21 PM. Reason: Automerged Doublepost
Old Nov 26, 2007 | 06:30 PM
  #1180
Darksun's Avatar
Im sorry if i ever doubted you paul.
Old Nov 26, 2007 | 06:31 PM
  #1181
Area47's Avatar
Rent me! per hour
well that came out of no where!
Old Nov 26, 2007 | 06:38 PM
  #1182
lol it's cool man. I told you I wasn't gonna be playing around with this car.
Old Nov 26, 2007 | 07:59 PM
  #1183
victory_red_SS's Avatar
LSX RWD S/C conversion
lol
Such as????
Go big or stay home, right???
Old Nov 26, 2007 | 08:57 PM
  #1184
you speak the truth oh wise one
here's some screen shots of the dyno datalogs
1st pull
2nd pull
3rd pull
Last edited by 06blackg85ss; Nov 26, 2007 at 08:57 PM. Reason: Automerged Doublepost
Old Nov 26, 2007 | 10:13 PM
  #1185
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Man maxin out those injectors aye? Might be time for some 100s
Old Nov 26, 2007 | 10:17 PM
  #1186
Delta2.2's Avatar
wait what??? how do u blow the turbo?/
Old Nov 26, 2007 | 10:40 PM
  #1187
2K5SS/SC?'s Avatar
That's what happens when you get a shitty knock off ebay turbo. I bet when Paul gets a real good turbo, his tuning issues and little quirks will be all worked out. R&D, gotta love it!
Paul, what are your plans for the IDC's? If you got the RKSport fuel pressure regulator, you could kick the pressure up to lower the IDC's. Just a thought.
Old Nov 26, 2007 | 10:53 PM
  #1188
jgarciarivera's Avatar
Or setup a return-style fuel system using the following:
Walbro GSS342 fuel pump.
Aeromotive A-1000 fuel pressure regulator
Old Nov 26, 2007 | 11:02 PM
  #1189
2K5SS/SC?'s Avatar
Is that walbro a direct fit? Damn these returnless style fuel systems. My damn Integra is so much easier to mod than my Cobalt.
Old Nov 26, 2007 | 11:09 PM
  #1190
The GSS342 is longer than the stock pump. The in-tank pump is "inline". Just replace the stock pump and when closing the "black module inside the tank" you'll see that you can't. Just tie with straps. Got some photos here.
https://www.cobaltss.net/forums/show...t=85970&page=2
Old Nov 27, 2007 | 06:07 AM
  #1191
exactly what I'll be running. btw how's tuning the fuel curves with the higher pressure?
Old Nov 27, 2007 | 08:05 AM
  #1192
In my case, I went to a dyno for fuel tuning. Set AFR@10.8
Old Nov 27, 2007 | 10:51 AM
  #1193
Area47's Avatar
Rent me! per hour
i do believe someone is out of fuel
Old Nov 27, 2007 | 10:55 AM
  #1194
I'm lost here. Who is out of fuel?
Old Nov 27, 2007 | 11:04 AM
  #1195
Area47's Avatar
Rent me! per hour
look at the logs. the injectors are done. 20+ ms. ouch. so. in "theory" the pump itself is done at what. 330 fwhp? which inturn causes the injectors to go close to static. or is it the fact that paul is commanding 10.8, but running 12.0 afr. still doesn't make sense to me. one of three things. the pump is done, the maf is skewed something fierce, or there is a booger in the fuel map somewhere?
Such as????
two round things with these cute widdle bumps on them
log fuel pressure perhaps?
Old Nov 27, 2007 | 11:38 AM
  #1196
I think he needs a new fuel pump.
Old Nov 27, 2007 | 11:47 AM
  #1197
Asphalt Assault's Avatar
Originally Posted by Darksun
Paul put out 356 whp at 6000 rpms on 22 psi 18 degrees of timing today. I don't know his tq but it was 307 tq on his 246whp pull His boost controller wouldn't hold anything over 22 psi so that what he worked with. He has vids and stuff he'll post later. He's still on stock clutch too so i really don't know what some of these other guys are complaining about.....
Well its not every car. but think of this. he wouldn't be the first car to loose out on #'s cause of a clutch.....LOL. Seriously though.... my clutch is a dud, it works well for street but at the strip it can loose its ability to stay clamped on the disk. You have to drive it alot and have it happen to you to believe it. enough said...
356/315 today uncorrected woot. vids loading up soon.
sorta fixed the fueling problem, well at least it didn't lean out.
1st pull 343/307
turbo cobalt, 1st pull of the day @21psi
2nd pull 347/311
2nd pull 22 psi 347whp 311wtq.
3rd pull 356/315
3rd pull, couldn't get it to boost higher than 22.35psi due to the boost controller.
Great #'s. I would love to see the Dyno map. can you post those?
What gear are you pulling in?
I saw the dyno screen. you pulled 356 early on then torque and HP fell off from there. you think it is due to just the fueling or just turbo or combination of problems?
Good work. hopefully you can build it up to do even more in the higher RPM band.
Old Nov 27, 2007 | 12:08 PM
  #1198
It was losing fuel pressure up top, but I also setup it up to keep TQ low since as said before, still rocking the stock clutch. As also stated many times, it has never slipped, no even on slicks in the 50+ passes I've had on the car.
But fuel is definitely an issue. from my readings my maf tables are spot on, so I'm pretty sure it's a delivery problem, also I really should change the fuel filter since it's the original one lol.
and for the injectors, when it's cold they hit 25+ ms and over 143% IDC. so I need to find a solution, and soon... also according to my maf and VE readings I had this turbo maxed out at 54.84 lb/min of airflow, so I guess it's time for something bigger.... and better of course.
Old Nov 27, 2007 | 12:54 PM
  #1199
Area47's Avatar
Rent me! per hour
lol
change the filter. you might cry when see what comes out of it. i know i did at 23k.
cram a 35r under it
live my dream man!
Old Nov 27, 2007 | 02:11 PM
  #1200
djt81185's Avatar
You can see where the injectors are doing weird **** right before they max makes is suck for driveability
