can you run e85 on #60's?
Old Aug 2, 2010 | 12:57 AM
sundevil07's Avatar
Chris they have the benefit of 93 octane so i can see 20-22 but 25 is reaching. Were stuck with **** 91 and 17* of timing. The meth on my old lsj helped alot. 24.5*
Old Aug 2, 2010 | 12:58 AM
EXsoccer1921's Avatar
Originally Posted by smthomas556
Its true it can be done and it has on my car. This was an experiment that we tried on my car and we were shocked. As soon as I sell my meth kit, https://www.cobaltss.net/forums/parts-66/sale-devils-own-progressive-meth-kit-223316/, (shameless plug there) then I will be purchasing 80's for more headroom.
let me guess you had enough nozzeling you could back off the e85 slightly and compensate with the meth thus lowering the duty cycle but you can still say "i ran 60s and e85
Old Aug 2, 2010 | 01:00 AM
SCcobaltSS's Avatar
Originally Posted by 05Slowline
I'll let you know when I get adventurous enough to get to work on that Need to fix my WB 02 first and I am teh lazy cause I just DD the car right now so no real care atm...Should be able to pull 20-23 no problem 25 if my car loves the timing as much as it has in the past...I ran 25 deg timing stock everything except an intake, don't really see it being too much of a leap with full cooling and only a 3.0. Right now I only have it at like 18 deg....which is what straight up ott 2.8 and 60 cars run lulz...
Hard to believe? Why's that? Boosting 13-14psi IAT2's reaching maybe 140 after multiple pulls, engine coolant never seeing higher than 190.....yeah you get the picture.
E85 you are also running a larger pulley so in the end sure maybe you get a few more horses, but a few more hp isn't really worth all the hassle .
Really don't see that happening when the whole rest of the community can't do it.....weird.
Ok I didnt see stock pulley, I guess I see pump gas cars around here hating timing due to high heat and **** gas. Still 25 is a lot.
There is no hassle, if you have the injector why not use it? Its kinda a free mod, you have to fill up, why not on E?
I have not only felt high end power I have felt power through out the power band. I really didnt feel the same on pump gas. So the "few" extra horse seems to be worth it.
Actually this is straight E, his meth was out of the car.
Yah I know. I realized that when I was typing my other post as you can tell.
Old Aug 2, 2010 | 01:01 AM
sundevil07's Avatar
Maybe because most of the "community" that are telling you it cant be done havent touched a laptop and couldnt tell you what cot, pe, sd, lamba, advance even is. You should know this.
Old Aug 2, 2010 | 01:02 AM
smthomas556's Avatar
The meth kit is off my car. Read my for sale thread. We have tuned without it since I started running E85.
Nice
Last edited by smthomas556; Aug 2, 2010 at 01:02 AM. Reason: Automerged Doublepost
Old Aug 2, 2010 | 01:03 AM
sundevil07's Avatar
Please stay out of threads you know nothing of. You tried e85? Go buy a cobalt and hptuners and dick around for a little while then come back.
Old Aug 2, 2010 | 01:04 AM
05Slowline's Avatar
Tis a hassle to route your route <- 2 different pronunciations around picking up e85. personally when i get my work vehicle in a few months i'm gonna get e85 just cause I won't be driving it everyday and there is a station a few blocks away. then the next closest is like 20 miles away. I just can't wait until e85 becomes even more widespread.
Is also a hassle because of the different blend changes and having to tweak for them...
Old Aug 2, 2010 | 01:06 AM
sundevil07's Avatar
So you do know what youre talking about. You just come off as a dick in every thread. LOL
Old Aug 2, 2010 | 01:08 AM
SCcobaltSS's Avatar
I can agree the only hassle I have is location........ but its worth it!
Old Aug 2, 2010 | 01:09 AM
Its amazing how once again a member asks a legitimate question and instead a dick measuring contest ensues.
Old Aug 2, 2010 | 01:11 AM
  #36
SCcobaltSS's Avatar
Oh nice sig, I couldnt see it all the way till now.
Old Aug 2, 2010 | 01:12 AM
  #37
Very worth it!
Yes thanks. I stole it from you
Last edited by smthomas556; Aug 2, 2010 at 01:12 AM. Reason: Automerged Doublepost
Old Aug 2, 2010 | 01:15 AM
  #38
05Slowline's Avatar
Really? You know that is funny. 60's and a 2.8 on pump gas is what like 80% IDC with an 11.5 AFR....So how do you go to a fuel that burns at a higher rate and a .10 smaller pulley and come out with the same IDC? I am VERY curious.
Old Aug 2, 2010 | 01:21 AM
  #39
SCcobaltSS's Avatar
On E you can run a little leaner than 11.5
  #40
05Slowline's Avatar
And before anyone says it yes the car was heatsoaking like a ************ and yes it was pulling timing, dead IC pump we found out after that run .
  #41
sundevil07's Avatar
iat of 45* buddy. You were probably negative da, ton of o2 in the air. We here in Arizona see days of damn near 5,000 da. Less o2, less fuel needed. I know my 60's were NO WHERE near 80 percent duty cycle
Old Aug 2, 2010 | 01:22 AM
  #42
05Slowline's Avatar
Which I realize, but mid 80 IDC on a smaller pulley and same size injectors, IDK.
Old Aug 2, 2010 | 01:24 AM
  #43
My 60's on 2.7 and meth were at 60%.
Old Aug 2, 2010 | 01:25 AM
  #44
05Slowline's Avatar
So I guess that that is where the difference lies, I've never had a part in tuning a car in an atmospheric change like that ha. Still like to see a log.
Hmm, so apparently then it's not THAT darastic of a change, considering the meth will free up some IDC, idk but hey if it works for you go for it, not gonna work for 95% of people on here though and I hope you don't take that car out of that change ha.
Old Aug 2, 2010 | 01:29 AM
  #45
sundevil07's Avatar
I just wanted to ruffle things up a bit since he IS running e on 60's. I know it wont work for most and when winter comes he will most likely need 80's (60 degree days) but it is still a cool experiment and all of us AZ guys were very shocked lol
Old Aug 2, 2010 | 01:31 AM
  #46
05Slowline's Avatar
Yeah no doubt learn something new everyday . Wish our winters were 60 deg days LOL.
  #47
I will be getting 80's once my meth kit sells. Well put Brett.
Old Aug 2, 2010 | 02:01 PM
  #48
ebristol's Avatar
Dam you guys stayed up late working on this! lol
Originally Posted by moranjames89
awesome info ebristol! the guy even posted his tune file that he had for the 3.1" pulley and #60's.. sweet!
what kind of whp can you expect with a 3.1" #60 injs. full exhaust 3", cai, cobra h/e?
I think it would be awesome to run e85, but if the power would be around the same as a 2.7" than I probably wouldn't waste my time.
IMO 60s and e85 is not worth it. If I can pull 20-25 deg of timing off of a 3.0 and 42's with dual pass, h/e, and option b, why go to a higher pulley and e85 to go slower?
If you're gonna do a 2.7 and e85 pay to play and get 80s.
I agree with slowguy with a couple of differences.
Powerwise
You are not going to make that much more running a 3.1" pulley on E85 vs running a 3.1" pulley on gasoline (On a car with proper cooling mods). But there is a power increase. I picked up like 7whp just by switching fuel on a 2.8" pulley. So on a 3.1" there might be a few ponies in there.
But I would be willing to bet that on a basic Stage 2 car. IE injectors and pulley, no other mods, that I could make at least 10-15 more hp with E85 or gasoline. E85 is a cooling mod. It burns much cooler then gasoline and controls heat much better.
I lot can be done with a good tune. I tuned a Cobalt to 291whp with very basic mods. E85, 2.9", HE, exhaust.
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/strongest-2-9-m62-car-217871/
Reliabilitywise
E85 is totally worth it. Like I said, it burns cooler then gasoline therefor it is less hard on your engine. It maintains engine temp and exhaust gas temps so much better then gasoline.
Costwise
This is tough. E85 is about 36% cheaper then gasoline in my area. Running E85 is going to cause your fuel economy to drop by around 30%. So for me it is worth it. You need to determine the cost different between E85 and premium fuel in your area to see if it is worth it for you.
my buddy, smthomas is running a 2.7 and 60's on e85. His car works just fine. He is tuned by sccobaltss I'll see if I can get him to post up in here and show logs
duty cycle is mid 80's iirc at 6800
buhahahahha no way.
Well ZZP did it on their first E85 setup. 60# with their BRFPS set at 70psi. Or a return style system like mentioned earlier.
But I do not think there is anyway to supplement enough fuel with Meth injection and E85 with 60s. That seems like a huge stretch.
Old Aug 2, 2010 | 03:54 PM
  #49
^^^ Well put.
Old Aug 2, 2010 | 05:48 PM
  #50
stealthy1ss's Avatar
To the OP, definately get the 80's. The cost difference is very minimal compared to the 60's and the 80's also give you a larger range of pullies that you can run.
https://www.cobaltss.net/forums/showthread.php?t=217871
Eric I know that you know the story of why I am running the 2.9 but the original plans were to run a 2.7. When I went to take the 2.9 off only one screw came out and the rest rounded out because I over tightened them 2 years ago.
