Strongest 2.9 M62 Car?
Old Jun 7, 2010 | 07:51 PM
stealthy1ss's Avatar
Went to a Dyno Day at a local shop yesterday and was absolutely stunned at the results.
Mods:
80# injectors
2.9 pulley
ZZP Midlength Header/Dp combo 1 ¾” primaries 3” to 2.5” dp gutted cat
Stock catback with a cut out
OTTP HE
Airbox Mod
Stock M62
E85
ebristol spot on tune
Numbers:
Graph:
Vids:
http://www.youtube.com/watch?v=gJGvpXMmAOc
http://www.youtube.com/watch?v=1iKIEWn7inU
As you can hear the car missfired around 6800 which leaves me to wonder if it has more. Eric thanks for the tune, its super bad ass!!
Old Jun 7, 2010 | 07:58 PM
Rodimus_Prime's Avatar
why do you need 80s for a 2.9? or are you planning on going big with a TVS later?
Old Jun 7, 2010 | 08:00 PM
My IDC's are around 80% with the 80's.
BLAZIN07SS's Avatar
I'm too JDM for you
he is on e85
PRND3L's Avatar
Originally Posted by rodimus_prime
why do you need 80s for a 2.9? Or are you planning on going big with a tvs later?
e-85
Old Jun 7, 2010 | 08:02 PM
blk06cbltss's Avatar
damn i really need to get my ss/sc dyno'd. i know im not 291whp but i know my speedo moves that fast =D and i have a 2.9 pulley
Old Jun 7, 2010 | 08:07 PM
ebristol's Avatar
Regap your plugs to .030-.032 and see if that makes a difference.
There is more power to be made in the tune. I thought it was more on the conservative side!
Old Jun 7, 2010 | 08:08 PM
Did you watch the WB? I think we could even lean it out a tad as well if need be!
Old Jun 7, 2010 | 08:12 PM
i need e85!!!!!!!!!!! its kinda hard to find it out west but when i lived in mi every bp had it
Old Jun 7, 2010 | 08:13 PM
05Slowline's Avatar
I thought eric said there was a very negligible difference on E for power off the AFR opposed to regular fuel?
That the same dyno you go on E?
Old Jun 7, 2010 | 08:17 PM
StreetLC's Avatar
God i wish i could get tuned on e85 =(
Old Jun 7, 2010 | 08:21 PM
100% METH's Avatar
do you have a stock dyno graph comparo on the same dyno?
Old Jun 7, 2010 | 08:33 PM
ebristol's Avatar
It looks like your AEM reads correctly when it is not sharing the signal with HPT.
I found very little difference in the HP/TQ so there is probably not much to be made up there.
The reason the car is running a little on the rich side is because of he AEM Uego Gauge was giving me different readings then the readings in HPTs. HPTs was telling me 11.5-11.8 and his gauge was telling displaying 12.1-12.3. Through the research I found that most people said that that gauge is correct and HPTs is wrong. So after I was done tuning I changed the commanded AFR in PE from 11.76 to 11.5 just to be on the safer side.
But it looks like the gauge is displaying correctly when not sharing the signal with HPTs.
No. I run on my local dynojet and this was a Mustang Dyno.
But after seeing these results I might need to make a trip to West Bend! jk
Aren't Mustang Dyno supposed to read lower?
cobaltguy889's Avatar
^^yes sometimes
Tyler is reppin. Good numbers man! I'm happy for ya!
Old Jun 7, 2010 | 08:42 PM
ebristol's Avatar
I did think that Tyler's car pulled really hard for a 2.9". Esp in the mid to high RPMS.
I did make a comment to him that it felt like his car was faster then mine. But mine definitely has more TQ on the low end.
Tyler. Post your results in here.
https://www.cobaltss.net/forums/dyno-results-170/official-dyno-thread-194257/
That makes you #2 on the list.
Old Jun 7, 2010 | 09:16 PM
https://www.cobaltss.net/forums/showthread.php?t=194257
I just posted my results in that thread. The itch for 300 has gone from "I have no chance" to "Get me on that dyno now!"
Old Jun 7, 2010 | 09:44 PM
ebristol's Avatar
Get a intake. ZZP or OTTP.
Old Jun 7, 2010 | 09:45 PM
BlackBaltSw's Avatar
Address to that dyno please!!!!!!!!
Old Jun 7, 2010 | 09:59 PM
West Bend Dyno in West Bend, WI. I don't have there address.
I want to get there the hard way.
Last edited by stealthy1ss; Jun 7, 2010 at 09:59 PM. Reason: Automerged Doublepost
Old Jun 7, 2010 | 10:44 PM
Pyros777's Avatar
That is awesome!
Old Jun 7, 2010 | 10:47 PM
selfinfliction's Avatar
good stuff man, can't wait till e85 is available around here
Old Jun 8, 2010 | 12:16 AM
firepinch's Avatar
Do you you think that he could have the same results if he had regular gas + methanol injection (something like 90% meth and 10% water or 100% meth with a big nozzle) ??? Is there any other factors than the fact that he could push up the timing in order to make more power with the E85?
So with a 2.6 he would get over 300 whp!
Old Jun 8, 2010 | 12:22 AM
Not to sure about getting the same results with 93 + meth. This car has more in it and I can see 300hp no problem with out using the 2.7 that I have for it. If you watch my wideband in the video you can see that it is running between 11.3 and 11.5 (at times dipping into the high 10's) so we could lean it out and possibly add a degree or two of timing. There is not too much room to go up in timing.
Old Jun 8, 2010 | 12:42 AM
ebristol's Avatar
Sort answer. No.
If you want to lean out the top part of the MAF then YOU get to drive! lol
Old Jun 8, 2010 | 04:35 AM
06cobalt racer's Avatar
just noticed on the numbers page it has you as a 2.4. would tgat affect anything with the numbers? just asking, never dynoed yet.
