cant do burnouts?
Old Dec 2, 2009 | 12:16 PM
D4u2s0t's Avatar
thats called an internal burnout.
Aren't they fun.
I personally would recommend a professional manual transmission operating course but I'm sure you've been driving standard for x amount of years and know what you're doing.
hence the reason I no longer try to help people, because even though they come and post that something they're doing is wrong, when you try to help you become the idiot lol
Old Dec 2, 2009 | 12:17 PM
Permafried-'s Avatar
Originally Posted by selfinfliction
next time just go out there, dump the clutch in first again at a higher rpm and after a little while, the tires may start spinning. hold it for about 20-30 seconds and come back, let us know what happened
....good excuse to go with aftermarket axles if nothing else
Old Dec 2, 2009 | 12:21 PM
scotch89's Avatar
wow lol
Old Dec 2, 2009 | 12:24 PM
ml2242's Avatar
Put on your winter tires and try It will break them in nice
Old Dec 2, 2009 | 12:26 PM
screw winter tires, take the tires off completely. spin the rims.
Old Dec 2, 2009 | 01:38 PM
phatnackySS's Avatar
just because it hasn't been said, its obvious your clutch has taken a dump. Its bad and time to get a new one.
Also dont shift durning a burnout, start in 2nd if your in a water box
Old Dec 2, 2009 | 01:44 PM
campo165's Avatar
i got 54k on the balt and i cant help but to spin thru second on the 1-2 shift. Clutch was either still cold, or bad. probably was a mixture of both at the moment. Also if you just burn thru 1st without gaining speed then hit second gear at like 10-15mph, thatll kill the clutch. real fast.
Old Dec 2, 2009 | 02:21 PM
Snakes709's Avatar
I wish i had this issue with my 370z. Every time i take off my tires spin abit, going to go through winter tires really quick.
Old Dec 2, 2009 | 09:18 PM
nicksredline's Avatar
if u want a nice smokey 1 get some bleach
Old Dec 2, 2009 | 09:42 PM
ßlĺçk§mókč's Avatar
If you cant find water.. just use the magic yellow stuff known as ****
Old Dec 2, 2009 | 09:52 PM
  #36
631motersports's Avatar
http://www.youtube.com/watch?v=quTeXhdfoA4
jus do what this guy did. should see sum good results
Old Dec 2, 2009 | 10:01 PM
  #37
hatrickstu's Avatar
stop shifting 1-2 when you are spinning in 1st. problem solved.
TedSS
101
Apr 25, 2016 10:46 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
selfinfliction
Sep 25, 2005 09:37 PM
