Can't figure out tapping noise
Old Mar 19, 2011 | 03:34 PM
chevy454400205's Avatar
I have this tapping noise coming from, what it sounds like, the top of the engine. I replaced the lash adjusters and rockers. Thought it was gone then came back. It comes and goes through various rpm ranges. Any ideas on where to look next?
Old Mar 19, 2011 | 03:51 PM
outtamymind's Avatar
timing chain tensioner
Old Mar 19, 2011 | 03:55 PM
How acessable is that? Are you able to do it with messing up the timing or pulling the engine?
Old Mar 19, 2011 | 04:03 PM
not sure, never had to do it. i'm sure someone who has will chime in on it. it shouldn't mess up the timing as your only inspecting it at this point.
Old Mar 19, 2011 | 06:58 PM
CanadianCobalt's Avatar
If it's a ticking noise, its the tensioner. Pull your plugs out so your engine settles then use a 32MM socket on the back passanger side of the engine to remove the old tensioner being careful it comes out in once peice. Then replace with the new one from www.crateenginedepot.com.
Replace plugs, proceed on with life as if it never happened. Minus noise.
Joel
Old Mar 19, 2011 | 09:04 PM
Cool. Thank you. Why pull the plugs? They are very new.
Old Mar 20, 2011 | 02:14 AM
It was reccomended to me by someone else so there is no compression in the engine so it doesn't try to move at all while the tension is released from the chain and jump timing. Not saying it will happen (I doubt it would) but pulling the plugs eliminates the chance and takes under 5 minutes. All it does is make sure wherever the engine is settled is where it is staying.
Joel
Old Mar 20, 2011 | 07:00 PM
LSJ's Avatar
LSJ
Joel
This is true.
Definitely take them out. My buddy was told this by ZZP in person.
Old Apr 9, 2011 | 11:56 PM
I replaced the tensioner and the tapping noise is still there. Anyone have any other idea on what to look at next. At the moment all I can think of are the injectors.
Old Apr 10, 2011 | 12:52 AM
JetBlackSS's Avatar
My throttle body ticked when it went bad. Went away when I revved it but would tick at idle.
Old Apr 10, 2011 | 09:30 PM
How did it go bad?
Old Apr 10, 2011 | 09:59 PM
Mine will still do it at different speeds and rpms. Cant say i here it on the highway though. But definitely on the streets.
Old Apr 10, 2011 | 10:07 PM
K-Train04RL's Avatar
an ss.sc can make a rattleing noise when the supercharger coupler goes bad...
Old Apr 10, 2011 | 11:07 PM
JetBlackSS's Avatar
How did it go bad?
Not sure exactly what caused it. Had 95k on it when replaced. Stopped hearing ticking after new throttle body.
Old Apr 11, 2011 | 12:27 AM
Well I will add the throttle body to my things to check. Its not really a rattling noise, it is very much like a tapping sound. But i will take the advice and give the coupler a look at also. Any other ideas would be appreciated seeing how I am now hunting for this problem and just slowly eliminating things.
Old Apr 11, 2011 | 12:40 AM
1fastSSBalt's Avatar
Post a video for us to better understand the sound if at all possible.
Old Apr 11, 2011 | 12:41 AM
BlueTurbo's Avatar
Are you absolutely sure it's coming from the top of the engine? If you have already replaced the tensioner, lifters and rockers, and it's definitely coming through the valve cover, then I would check your oil pressure. It may be that the lash adjusters aren't receiving enough oil, and partially collapsing as they operate. Blocked passages or casting flaws could be the cause of this. Also if you have access to a scan tool, try killing fuel to the cylinders. If the noise changes, you can just about guarantee it's a rod bearing or similar in the rotating assembly. Hope this helps.
Old Apr 11, 2011 | 11:28 AM
I do have access to a scan tool so will be doing that. Whats weird though is the noise comes and goes.
Old Apr 11, 2011 | 01:04 PM
BlueTurbo's Avatar
Do you have any oil pressure concerns? Or possibly oil consumption?
Old Apr 11, 2011 | 04:53 PM
Engine was just rebuilt. Installed forged pistons, destroyed stockers. But tapping noise has been there since then. I will check everything tonight and post. And will take video too.
Old Apr 12, 2011 | 08:10 PM
Oil pressure checked out ok. Killed each cylinder with computer and noise never stopped once.
Old Apr 12, 2011 | 08:39 PM
Here is a video of the tapping noise. Hopefully i post it right
YouTube - P4110015
Old Apr 12, 2011 | 10:06 PM
BlueTurbo's Avatar
That definitely sounds like a valvetrain tick. It only started after the rebuild? What exectly did you replace?
Old Apr 13, 2011 | 12:45 AM
It was only the bottom end. One new sleeve and put in all forged pistons.
Old Apr 13, 2011 | 03:20 AM
I'm not professional here but I hear the "ticking" noise, if you will, through all the variations of RPMs you had whom ever rev it to. Sounds similar to a valve tick to my ears. My friend's jeep was just making this similar noise, no CEL thrown or anything and he just experienced valve float which in turn blew his motor.
I have heard this noise plenty of times and I am almost willing to bet an issue with a valve but I will stand corrected if proven wrong.
Just my .02 cents, would appreciate some insight from someone who has much more knowledge than I on our platforms as well as an over all mechanic aspect.
P.s I did tell my friend his valve was going to end up floating and sure as **** a week later he floated a valve and damaged piston #3.
