Can't figure out tapping noise
Found out the head gasket wen't bad around one cylinder. Stock head gasket was used. Head is now at the machine shop. Hopefully this was the cause of the tapping noise. Should I put a new stock head gasket back on or use another?
I have that exact same noise, I thought it might be the tensioner but i guess not. Anyone know whats making that noise. Kinda worried
Got my car back and everything seems to be fine. They said the sleeve hadn't come loose. Machined the head, put some new valve springs on, that as the next thing I was going to replace, and car runs fine. No noise and clutch feels solid again. Hopefully everything remains solid.
I have the same issue. I rebuilt my motor Diamond forge pistons and zzp 78# valve springs. Ever since i did that I've had a tapping issues. I'm going to check the valve stem to rocker clearance tomorrow. That seems the most logical to cause noise. If the clearence is bad it will just give me a reason to take the head off and get it ported.
Did you replace the vavles?
DANRICKARD
Oct 1, 2015 12:08 AM
