Can't get meth pump to come on..
Old Jan 26, 2009 | 06:35 PM
RedEcotecSS's Avatar
So I hooked up my meth kit and everything but it just won't work. Got the ais trunk mount stage 1. I blow into the boost hose and it didn't spray at all. Nothing happened. Couldn't hear the pump run or anything. I can't figure it out. I'm confused as ****. Anyone had a similar problem?
Old Jan 26, 2009 | 06:37 PM
ShortStack's Avatar
What boost do you have the meth pump to set pumping on?
Old Jan 26, 2009 | 06:39 PM
I turned it all the way down to test it. There wasn't a relay it was all pre wired
Old Jan 26, 2009 | 06:44 PM
ShortStack's Avatar
that turns the pump off
turn it up to 11psi
ive heard the trunk mount system needs to be at atleast 11-12 psi
Last edited by ShortStack; Jan 26, 2009 at 06:44 PM. Reason: Automerged Doublepost
Old Jan 26, 2009 | 06:54 PM
Update
I just wired just the pump to see if it was bad and it came on. I guess the wiring from the pump to the boost thing is messed up? About to take pump off the tank now to see if its wired right
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
