Can't remember the name of a certain clutch
I believe it was posted on here or cobaltssdotcom. It was a really nice clutch with a few stage options for sale. It wasn't spec or exedy from what I can remember. I tried to search for it but had no luck finding it. I have experienced quite a bit of clutch slippage since I have owned my 07 ss and it is very annoying at times. I want to upgrade to one that will not have problems after I upgrade my full exhaust...that way once I get the Stage 3 kit(more then likley from ZZP) I won't have anymore slippage if and when I get on it. Thanks for any help xD
This clutch they say is good up to 300hp. This is what I had installed, and it does the job.
The thing to remember about most of the other clutches is that they don't come with a throw-out bearing. The GMPP Clutch does, however. And it's way cheaper than the other ones.
There's also some sort of clutch pipe that they typically recommend you replace while you're swapping the clutch to, which can also be found at crateenginedepot.com
No problem.
When you put a new clutch on, or so I've been told, it doesn't slip any more. More grip = more transfer of torque to the transmission. Which I hear, is also more detrimental to the tranny.
Spec clutches are way more grippy, but aren't necessary unless you are pushing a **** ton of power. a 300whp max clutch is plenty of clutch unless you plan on TVSing soon.
