Car Died...Again
Old Jan 29, 2008 | 08:10 PM
cobaltBlackss's Avatar
Car Died...Again
It was raining on the way home and I got stopped at a light two blocks from my house. I took off like normal and got really bad wheel hop and heard something pop. the whole front of the car was shaking, then bang. I tried putting it in gear and it wont go. It sounds like somthing is banging around in my engine compartment. What could it be???
Old Jan 29, 2008 | 08:15 PM
Red2.4SS's Avatar
The broken parts of your transmission I would assume from your story!
Old Jan 29, 2008 | 08:17 PM
I'm hoping I didnt break the tranny...maybe its something less serious
XM15's Avatar
Nothing good, thats for sure. Good luck.
Originally Posted by cobaltBlackss
I'm hoping I didnt break thhe tranny...maybe its something less serious
Doubtful
Old Jan 29, 2008 | 08:18 PM
Red2.4SS's Avatar
have you checked underneath to make sure the axles are OK and there is not leaking fluid?
elecblue06's Avatar
list your mods... them maybe we'll be able to help.. and i know it says look in your garage but if you list them it'll just be easier
YellowRocketSS's Avatar
ya it sounds like maybe something in the tranny or maybe an axle. good luck with it though sorry for ur loss.
Old Jan 29, 2008 | 08:21 PM
camarokiller's Avatar
sounds like an axle to me. It was probally flopping around after it broke.
lots of engine work, upgraded axels, solid mounts, spec stage 3+ clutch, lightweight flywheel
Old Jan 29, 2008 | 08:23 PM
Thats what I thought too. I didn't see it though. Would the car not move at all if this were the case?
elecblue06's Avatar
could be broken shifter linkages, busted axles, cracked tranny housing, all of the above or something in the engine
Old Jan 29, 2008 | 08:24 PM
I don't think it's the engine, it still revs up fine. Hopefully it's the shifter linkage, I broke those when I was still stock.
Old Jan 29, 2008 | 08:36 PM
elecblue06's Avatar
yea might've broken your mounts too depending on how bad the hop was.. i would doubt axles though since you have upgraded axels but who knows... either way good luck man
Old Jan 29, 2008 | 08:57 PM
Slowbalt SS05's Avatar
I vote for the tranny mine went out in 5th gear and I would get a grinding noise while I would drive the car. Got it fixed but it was my gear that popped out and flooding all over the place. In other hand you had wheel hop you may have cracked you tranny case.
Old Jan 29, 2008 | 09:14 PM
No grinding, just the bumping noise and no movement
Old Jan 29, 2008 | 09:21 PM
Lift your car up and check the axle boots if your drive axle boot is ripped its going to be the axle. You can find this out my having a lot of grease all over the boot and axle. My brother had the same problem with his VW golf VR6.
Old Jan 29, 2008 | 09:48 PM
I checked the axels, and no rips. Also, no leaking tranny. side note- the mph goes up like the car is moving.
Old Jan 29, 2008 | 09:58 PM
Tranny or Flywheel but its going to be something that has to do with your tranny, you should get it checked, when you RP jump but no movement the clutch is not grabbing or your Flywheel’s teeth are all grinded down. Or busted Tranny sorry man it may just be your tranny
Old Jan 29, 2008 | 10:05 PM
dbeausoleil57's Avatar
Piston.. I had the EXACT same problem when I first bought my car. I had a cracked piston with an oil leak down #2 cylinder. It died on the freeway but started back up like 20 minutes later. After it happened my car ran extra slow.. It clogged the catalytic converter and I was boosting like 20psi I didn't know wtf was going on with it until I took it to the dealer and they tore the engine down and found the problem with the piston.
Old Jan 29, 2008 | 10:39 PM
luckily it happened right next to the dealership so I'll get it checked out first thing in the morning.
Old Jan 31, 2008 | 09:26 PM
The verdict is in, I ripped my cv joint. Evidently the passenger side half-shaft is in two pieces. These were supposed to be rated at 400 hp and I'm not making that kind of power, so I don't know what the deal is.
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
no_ss
Sep 18, 2015 11:03 AM
