Car feeling sluggish after 2.8 install
Old Jun 29, 2006 | 02:54 PM
InfiniteEffect's Avatar
Okay, I just installed my Pulleyboy's 2.8 yesterday along with disconnecting the negative battery terminal for the ECU relearn. Maybe I just need to wait a few days for the ECU to get right? It feels like it has lost power since Stage 2. I know it's working right because I'm making 17+ PSI. Let me know your thoughts
Old Jun 29, 2006 | 02:58 PM
06black's Avatar
hmmm...i'd check every thing..the ECU re-learn takes around 20-30min.
Old Jun 29, 2006 | 03:02 PM
MarcS's Avatar
The Stig
You should be running colder plugs.
Old Jun 29, 2006 | 03:10 PM
OniMirage's Avatar
x2 get some brk7e's gap to .40 good to go
Old Jun 29, 2006 | 03:16 PM
codyss's Avatar
For a couple days after unhooking my battery after experimenting with air filters my car was embarassingly slow and terribly slugish.
Now it's fast as hell. I think the ECM is just a very slow learner.
Old Jun 29, 2006 | 04:27 PM
OUTPR4MZ's Avatar
is there enuf tension on the blower
Old Jun 29, 2006 | 06:50 PM
M62SS's Avatar
how about if you dont touch the battery and just go after installing the new pulley...anybody try that...
Old Jun 29, 2006 | 06:53 PM
Matty's Avatar
I have never disconnected my battery.
Old Jun 29, 2006 | 07:49 PM
Nuclear's Avatar
i didn't either
Old Jun 29, 2006 | 08:04 PM
zinner's Avatar
Moderator Alumni
The ecu learns one thing, fuel trims. Fuel trims have no effect on WOT driving.
In short the something else is wrong if it's sluggish.
Old Jun 29, 2006 | 08:18 PM
StreetDreamz's Avatar
Umm...did you put in some larger injectors? You should be running at least 50lb injectors on a 2.8 that goes to 7,000rpm.
Old Jun 29, 2006 | 08:23 PM
zinner's Avatar
Moderator Alumni
I have a 2.8 and 42# injectors. Whats the problem?
Old Jun 29, 2006 | 08:30 PM
Saki XL's Avatar
Make sure your Sparkies are gapped... 42.5 lb/hr Injectors should suffice even if you don't go to 7000 RPM redline --- the car should not be sluggish getting there.
Old Jun 29, 2006 | 11:34 PM
M62SS's Avatar
is the sc whine is a lot louder with a 2.8 than the stage 2 pulley cause the whine from stock to stage 2 is a lot louder...i just cant wait to hear that...
Old Jun 29, 2006 | 11:37 PM
Shortbus's Avatar
I have 42.5lb injecotrs, and 7k redline, my injectors have never been maxed out, everything works well with the set=up with hp tuners.
Old Jun 30, 2006 | 03:16 AM
06black's Avatar
becarefull with what your sayin about that....
totaly depending on your tune a 2.7 is MORE then able to max out the 42.5lb injecters.
with my current tune...with 2.7/42.5lbs i'm at 115% duty cycle up high.
but its dependent on how agressive you went with your tune....lil fyi if nothing else.
Old Jun 30, 2006 | 07:38 PM
balts2thewall's Avatar
So if i go with a 2.7 pulley then i'll need bigger inj. than 42lb.?
Old Jun 30, 2006 | 08:18 PM
Yes.
As I said before. With the 2.8 you should be running at least a 50lb or so.
Old Jun 30, 2006 | 08:44 PM
Shortbus's Avatar
It is a very aggresive tune, and there not maxed out, we have done many runs with the hp tuners monitoring it, and its fine, it all depends on how you tweak the car.
Old Jun 30, 2006 | 09:04 PM
Rogue's Avatar
a 2.8 will max out 42.5 injectors above 6500 which is why we offer a 2.9 with our stage 3 kit and 60lb injectors with pulley sizes smaller than 2.8.
Old Jun 30, 2006 | 09:29 PM
memphisr24's Avatar
Wait....I thought 42.5 lb/hr injectors were good until ~290 whp. (I saw it somewhere on this site) How much can the 42.5 injectors handle whp wise? I just installed mine today and want to install my 2.8 next week with a 7000 rpm rev limit...which u guys are saying will be maxing out the 42.5 ers ??
Old Jul 1, 2006 | 10:23 AM
Whoever's idea it was to rate injectors by horsepower level need be shot in the head. It involves BSFC, rail pressure, air density, etc. Do the math. Listen to the people who know. And just do what they say. By leaning out your injectors the car will actually try to run richer by default. Which obviously can't happen, so it is probably pulling timing. Is this an Intense tune or just a straight HP Tuners tune? Because I bet the Intense is more in depth on what they remove/modify. Put the 60s in there and you will never have to worry about it again. But at that point you might as well get the 2.5 also. Just my two cents.
Turbo Johnny
Feb 21, 2019 09:41 AM
63 Nova SS
Sep 12, 2015 11:21 PM
ATOMbomb
Sep 11, 2015 10:48 AM
medic710
Sep 6, 2015 08:53 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
