car runing like crap
Old Jul 24, 2008 | 08:04 PM
Inferno's Avatar
i've been having problems with my engine idle.when i push the cluch in while decelerating the car wants to stall. i took it to gm they coul't find the problem. the wierd thing is it only does this when the ac is on. any thought guys?.
Old Jul 24, 2008 | 08:06 PM
BumbleBee's Avatar
how could GM not find the problem?
Old Jul 24, 2008 | 08:07 PM
thatotherguy's Avatar
Maybe spark plugs, MAF sensor, or the throttle body... not sure though just my guess
Old Jul 24, 2008 | 09:04 PM
Inferno's Avatar
i just put plug in a month or to ago. the ac is affecting the rpms so what would clean the throttle body do?, what should i use to clean the maf sensor?.
Old Jul 24, 2008 | 09:05 PM
25bduse's Avatar
finally
I am not the only one with this problem....same exact problem here....only when a/c is on
Old Jul 24, 2008 | 10:33 PM
johnladow07's Avatar
alot of balts have his problem...including me
Old Jul 24, 2008 | 10:36 PM
NS06G5's Avatar
I think I remember a how to on this about cleaning the throttle body to clear up this very problem. I have a 2.2 but it's doing the same damn thing. I tried to find the link but I suck at using this damn seach engine.
Old Jul 24, 2008 | 11:30 PM
theneelster's Avatar
Okay...so it only happens when the a/c is on. I would think that would make it a power draw issue. I don't think cleaning the t/b will help but it may, that smooths out rough idle when you idle at a stop; I'm thinking voltage problem; why not try a voltage stabilizer? No...I'm completely serious. 30 bucks couldn't hurt???
That's if you don't have hp tuners to fool around with idling rpm (ie raise it).
Old Jul 28, 2008 | 07:45 PM
Inferno's Avatar
anyone else having this problem?
Old Aug 16, 2008 | 12:18 AM
Inferno's Avatar
bumpy
Old Aug 16, 2008 | 12:22 AM
ItalianJoe1's Avatar
It acts like it wants to stall, but then it comes back up, right?
Old Aug 16, 2008 | 12:47 AM
Inferno's Avatar
exactly
exactly
Old Aug 16, 2008 | 12:49 AM
Unfortunately, its just something these cars do. If mine did it more often or it bothered me, I'd look into adjusting the A/C torque settings in HPT, so the car could better handle the extra load when you disengage the clutch. I would say to try and not worry about it, I've yet to see a fix for it.
Old Aug 16, 2008 | 01:31 AM
CBodnar's Avatar
my car used to do it real bad then i took off the throttle body which is like 4 bolts then i got trottle body cleaner and cleaned it out. it stopped doing it and now only some times every once in a while if the a/c is on full blast and i let off the clutch slow and let the rpm's dip to much and don't force a little extra gas it could stall or get close
Old Aug 20, 2008 | 07:28 PM
Inferno's Avatar
so i'd be better to pull of the tb and clean instead of leaving it on and try to clean it?
Old Aug 20, 2008 | 07:38 PM
CBodnar's Avatar
i'd clean the throttle body if i were you. see what happens. if you like the results you fixed your problem like i did with mine. if you fail. take it apart make sure you clean it really good. then if you still have problems. idk what else to say
Old Aug 20, 2008 | 07:46 PM
Inferno's Avatar
since ive never done this before, is the tb cleaner an airsol?
what should i use to clean it, a rag, tooth brush etc.
Old Aug 20, 2008 | 07:51 PM
ssaddiction's Avatar
had this problem cleaned my throttle body problem solved...goodluck takes 15 mins
Old Aug 20, 2008 | 08:43 PM
FryLoch's Avatar
I have the same problem but only when the car is cold. Once it gets up to operating temp it stops. When the motor idles down like that though, it shuts off the AC for a couple seconds which makes it take forever for the air to get cold. I have to tell you, that sucks ass down in Texas where the average day is 102...
Old Aug 21, 2008 | 07:26 PM
Inferno's Avatar
thanks for the help guys, i cleaned the tb and now it runs like a top.
Turbo Johnny
Feb 21, 2019 09:41 AM
Bluelightning
Nov 11, 2015 02:41 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
breds2k
19
Sep 21, 2015 10:24 AM
SS_2009_TC
Sep 11, 2015 05:41 PM
