car runing like shit
took the car to gm to do the stage 2 reflash for idle flucuation but they stage all the engine codes and software was up to date.so everytime i decelerate and push in the clutch the car alomost stalls,the rpms drop to about 500 then flucuates between 750 and 1000. So guys what else could be the problem?. I was thinking maybe the fuel filter??.
what would cleaning the tb do?.
I had the exact same problem until I cleaned out my throttle body. Once I did that, it was like a totally different car. Before you waste your time and money on anything else, clean out your throttle body.
the GM stage 2 tune is **** man.... someone was drinking when they made it. I swear to god it is one hell of a **** tune. I could go on and on about it, if you have hptuners i could give you a baseline on what to use.
hmm when i did my stage 2 it ran great i have a 2007 and only had 12 grand now i have almost 16 grand and still running good this is the first ive heard of someone having problems with a stage 2 upgrade without solving it with a quick fix
wow, wtf CAI do u have?
BTW
if u want to check out my conservative GM stage 2 tune that GM should use instead of the drunk **** that built it use this as a baseline....
GM Stage2 Dialed
keep in mind timing wasnt touched for safety reasons
Altitude was for 1000 feet above sea level
Piston Protection and COT left enabled so it will run rich under WOT but it will remove alot of the other **** GM thinks is "proper"
go ahead and check it out
BTW
GM Stage2 Dialed
shouldnt but if anyone is having problems ill put it on another upload site.
btw any flamers on here, be prepared for logs to show u how conservative my tune is AND the hp i give compared to the Stock s2 tune....
I have logs of both
I have logs of both
Profanity is not allowed in thread titles.
https://www.cobaltss.net/forums/lounge-42/read-me-about-foul-language-thread-titles-98610/
Just trying to look out for fellow members. Trying to do my part on keeping this site good. Been trashed too much lately.
