car runing like shit
Old Jul 1, 2008 | 06:09 PM
Inferno's Avatar
Question car runing like ****
took the car to gm to do the stage 2 reflash for idle flucuation but they stage all the engine codes and software was up to date.so everytime i decelerate and push in the clutch the car alomost stalls,the rpms drop to about 500 then flucuates between 750 and 1000. So guys what else could be the problem?. I was thinking maybe the fuel filter??.
Old Jul 1, 2008 | 06:10 PM
Connor05's Avatar
dude same things been happening to me for a while, but only when i have my a/c on =(
Old Jul 1, 2008 | 06:11 PM
XM15's Avatar
Clean your TB and see if that helps.
Old Jul 1, 2008 | 06:13 PM
Inferno's Avatar
mine happens all the time, ac on or not.
what would cleaning the tb do?.
Old Jul 1, 2008 | 06:19 PM
SS FREAK's Avatar
Change your plugs.. my cars rpm's were going up then down, up then down, u might need to re-gap them. let me know if that helps.. im kinda going through the same problem
Old Jul 1, 2008 | 08:03 PM
Inferno's Avatar
i put new plugs in and gaped them but the problem was happening before i changed plugs.
Old Jul 1, 2008 | 08:04 PM
kenhebe's Avatar
I had the exact same problem until I cleaned out my throttle body. Once I did that, it was like a totally different car. Before you waste your time and money on anything else, clean out your throttle body.
Old Jul 1, 2008 | 08:05 PM
chris88z24's Avatar
GM Stage 2 tune <3
Old Jul 1, 2008 | 09:15 PM
SS FREAK's Avatar
GM Stage 2 tune <3
dude im sorry to dawg you but for some one with 220whp and 190wtq only running a 14.4.. i would not be trying to get people to listen to me on here.
Inferno's Avatar
i'll try and clean the tb and see what happens. also the fuel filter. is there any else that could cause this problem?
Old Jul 1, 2008 | 10:04 PM
rrutter81's Avatar
the GM stage 2 tune is **** man.... someone was drinking when they made it. I swear to god it is one hell of a **** tune. I could go on and on about it, if you have hptuners i could give you a baseline on what to use.
Old Jul 1, 2008 | 10:07 PM
M-Dub's Avatar
get some maf sensor cleaner, clean it off, clean the tb, change the plugs.....
If not it's a GM flash issue!
Old Jul 1, 2008 | 10:13 PM
rrutter81's Avatar
he has an injen CAI
im sure its not MAF related, it would take 40,000 miles before it would cause one
Old Jul 1, 2008 | 10:16 PM
siphon_78's Avatar
hmm when i did my stage 2 it ran great i have a 2007 and only had 12 grand now i have almost 16 grand and still running good this is the first ive heard of someone having problems with a stage 2 upgrade without solving it with a quick fix
M-Dub's Avatar
The MAF gets dirty.... I clean mine every 3000 miles
Old Jul 1, 2008 | 10:19 PM
siphon_78's Avatar
well i guess mine needs a cleaning i really dont want problems soo ill check mine out
Old Jul 1, 2008 | 10:21 PM
rrutter81's Avatar
wow, wtf CAI do u have?
BTW
if u want to check out my conservative GM stage 2 tune that GM should use instead of the drunk **** that built it use this as a baseline....
GM Stage2 Dialed
keep in mind timing wasnt touched for safety reasons
Altitude was for 1000 feet above sea level
Piston Protection and COT left enabled so it will run rich under WOT but it will remove alot of the other **** GM thinks is "proper"
go ahead and check it out
Old Jul 1, 2008 | 10:27 PM
siphon_78's Avatar
do you have to register to that site to get that file??
Old Jul 1, 2008 | 10:29 PM
rrutter81's Avatar
shouldnt but if anyone is having problems ill put it on another upload site.
btw any flamers on here, be prepared for logs to show u how conservative my tune is AND the hp i give compared to the Stock s2 tune....
I have logs of both
Old Jul 1, 2008 | 10:33 PM
siphon_78's Avatar
well thanks since i have a stage 2 tune i might look at this file for a baseline
Old Jul 1, 2008 | 10:34 PM
Blackout06LS's Avatar
-waits for a mod to come in-
If you can edit your title. Do it now! Before you get caught.
Old Jul 1, 2008 | 10:35 PM
siphon_78's Avatar
before i get caught??
rrutter81's Avatar
what are you talking about?
Old Jul 1, 2008 | 10:36 PM
siphon_78's Avatar
i was wondering the same thing
Old Jul 1, 2008 | 10:37 PM
Profanity is not allowed in thread titles.
https://www.cobaltss.net/forums/lounge-42/read-me-about-foul-language-thread-titles-98610/
Just trying to look out for fellow members. Trying to do my part on keeping this site good. Been trashed too much lately.
