Car shut off last night
Hey I know there are some threads about this but just wanted some clarification. I was out last night driving normal (cause gas is so freaking expensive). I come to a light to make a right and as I am making my turn, some speed racer in a BMW comes booking it around a bend, so I punch it so I don't cut him off. As I do that, the car seemed to cut the fuel, I had no control over the throttle, but all the electrical stayed on. The car coasted to a stop with a knock at the end. No codes or anything in the DIC, and it threw a CEL. I tried starting it immediatley and it would just crank but not turn over. After a 5 mins I tried again and it started with a CEL, and it smelled like rotten eggs. After 15 mins of driving, and turned off the car, let it rest for about 10 mins, and started again fine, with no CEL.
Is this the common issue everyone is talking about? What causes this and what's up with the smell?
Thanks for your help
Originally Posted by Permafried-
Sounds like it could potentially be a clogged up Cat since you happened to mention the rotten egg smell. Take it to your dealer and have them check it anyways in case they can check the history of codes thrown.
Originally Posted by CTCOBALTSSS
Exactly and clogged cats are a big problem with the ss/sc so they should cover all cost!
nah... **** happened to me once... i didnt get the cell part though.. i just let the car sit a few minutes (i believe i hit the fuel cut-off).. car died but all power was still on.. same with cranking.. it would crank but not fire as if timing was cut off.. then it started up.. drove fine.. never had the problem since
brickloaf
09-06-2015 05:55 PM
