Intense ECU Installed!!!
After waiting 2 months for my GM kit, I finally cancelled the order and ordered the Intense Stage 5 ECU, 60lb Injectors and Harness. I got everything in the mail Monday morning and I had it installed this morning along with my Billetflow 2.7" Pulley.
Let me tell you.....This car ******* screams now. from a roll in second gear it is a tough job for both the clutch and the tires to keep making forward progress. The boost hits sooner and harder than I could have ever imagined and it doesn't stop until 7000rpm!! The feeling is unreal.
I am hoping to be able to get to the dyno sometime this week. I want to check out the a/f ratios to make sure everything is in check and that CAI isn't causing any problems. I will post the results when I have them.
Awesome work Intense, keep the good stuff coming!
Originally Posted by BooSSted
The CASE relearn is done. The scanner that was used just couldn't clear the code for some reason.
What did u tell the dealer? Don't flash the computer and just perform the CASE with a Tech 2 scanner? I'm nervous about buying the Stage 5 because I don't want my dealer to screw the thing up by flashing it and erasing the new tune
The tech II can clear the code. The one we used didn't have the full 2006 update so it couldn't clear the code off the ECU. From what I have been told, the scanners at the dealerships are updated every 2 weeks. I had mine done in a small shop, not the dealer
what a mean is even the code scanners you buy at canadian tire can clear that code, I find it odd that the Tech 2 can't.
I know because I have the p0017 code ( cam to crank angle) that comes on because of my cams and I have had it cleared many times.
I would love to see your car run at the track....come with us on Sunday!!
https://www.cobaltss.net/forums/canadian-mid-east-111/occ-test-n-tune-%40-cayuga-sun-jun-11-a-22042/
Hahahaha, thanks for the offer but I'll pass
Boost is at least 17 Psi, I don't pay a lot of attention to the guage when driving, especially at WOT.
I may upgrade to the 2.5 but the 2.7 is working great for me right now. Less chances to break things with the 2.7 as well
Also depending on what 2.7 your using he would need supercharger snout . With INTENSE anything below and 2.8 needs a supercharger snout. but with ZZP
" pulleys do not require snout maching. By developing Ecotech specific pulleys we run all the way down to 2.6" w/o snout machining."
Also Stage 5 is alot of money
"INTENSE™ LSJ Stage 5 Performance Package
Quantity in Basket: none
Code: LSJ-Stage5
Price:$999.99"
Code: LSJ-Stage5
Price:$999.99"
