Intense ECU Installed!!!
Old Jun 7, 2006 | 02:04 PM
BooSSted's Avatar
Cost increase for Stage 5 is because of the porting of the supercharger.
I am running a billetflow 2.7" pulley and it clears the snout just fine!
Old Jun 7, 2006 | 02:06 PM
NightriderCobaltSS's Avatar
so u didnt have to replace you snout with the 2.7 ?
Old Jun 7, 2006 | 02:09 PM
BooSSted's Avatar
Originally Posted by NightriderCobaltSS
so u didnt have to replace your snout with the 2.7 ?
Nope, It fits over the stock snout easily
Old Jun 7, 2006 | 02:12 PM
Couple of my friends are doing like a mild to wild thing. One of my friends is getting 60lbs injectors but with a 2.5 pulley and i am getting the 45lbs with a 2.7 .
Old Jun 7, 2006 | 02:14 PM
Sunburst_SS's Avatar
Originally Posted by SS4ME
Does anyone know how much a Tech 2 costs? I have been searching the past few days and can only find hard facts, no pricing. I imagine it is quit expensive!?
for a tech at our dealership to purcahse a tech2 it's around 2500 bux......probably more then that if you try buying one off someone outside the dealer
Old Jun 7, 2006 | 02:16 PM
max_boost's Avatar
Come on, all I need is a figure!
I think they are at least a couple thousand dollars maybe more.
One of the guys from Intense said that you should be using the 60lb injectors with a 2.7" pulley.
Old Jun 7, 2006 | 08:54 PM
blowncobalt's Avatar
Awesome can't wait to get my intense kit.
Old Jun 7, 2006 | 09:44 PM
I was going to use the ZZP or billet flow pulley 2.7 or 2.8 but on intense website it states
**** we recommend colder spark plugs, 42.5 lbs/hr fuel injectors and custom supercharger snout machining with the 2.70" and 2.60" supercharger pulley sizes
Strait from the website.
Old Jun 7, 2006 | 11:45 PM
BooSSted's Avatar
All I can say is that they sell the 60lb injectors with the stage 4 kit and the 2.7" pulley. They must do this for a reason
Old Jun 8, 2006 | 01:27 AM
CobaltSS422's Avatar
I wrote an email to Intense a couple days ago inquiting about their Stage 5 tune and injectors and how small of a pully and this is what I got....
me:"Right now I
have no baseline dyno and have installed Stage 2 from GM, Corsa Sport
Cat-Back and I have a SFPH 2.80" pulley that I plan on putting on.
How much smaller can I go with the 42.5lbs/hr injectors from GM Stage
2.>>
Intense: "With a 6,500 RPM rev limiter, we don't recommend going below 2.80"
pulley size with 42 pound/hour fuel injectors. With a 7,000 RPM rev
limiter, we don't recommend going below 2.90".
Old Jun 8, 2006 | 10:13 AM
  #36
BooSSted's Avatar
Just get the Intense Tune and the 60lber's and go ***** deep!!
Old Jun 8, 2006 | 10:17 AM
  #37
djt81185's Avatar
***** DEEP FTW!!!
Old Jun 8, 2006 | 10:20 AM
  #38
BooSSted's Avatar
Ftw?
  #39
snobird's Avatar
if you need a tech 2 i can get them but its gonna cost you 1800 + shiping it is used and dose not come with case but u can get a new one with the CANdi module for like 3800 shipped
Old Jun 8, 2006 | 12:02 PM
  #40
djt81185's Avatar
ftw = for the win
Old Jun 9, 2006 | 11:24 AM
  #41
Rogue's Avatar
We had some older wording on our pulley pages, but that has been fixed. We recommend down to a 2.8 pulley with the 42.5s and a 6500 redline (stock). If you upgrade the computer with higher redlines you should move up to a 2.9 pulley or install 60lb injectors with 2.8 and below.
Old Jun 9, 2006 | 02:25 PM
  #42
glockglade's Avatar
i don't know why you say you cannot run a 2.7 w/42 pounders i am doing a 2.8 right now with the stage 2 injectors and i am reading around 11.7 a/f at full load you should have more than enough room to run a 2.7 unless i am just lucky or something.
just my .02
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
